Where are all teh ground points?
use your current wire harness, connect the grounds the exact same place on the new engine.
or are you asking where to wire the ground? pretty much any structural part of the car, unibody, core support, any ground wire(usually black), etc...
I mean..
There's one wire that goes from the top of the valve cover to the top of the radiator support...
There is a wire that goes from teh tranny to the frame?
Where else?
Where else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psycho.chicken »</TD></TR><TR><TD CLASS="quote">I mean..
Where else?</TD></TR></TABLE>
and the wire from the tranny to the frame to the negative terminal on the battery
also there is a ground by the thermostat housing a 10 mm bolt
Si-Yaaa!
Jul 14, 2003 12:40 PM
