real quick question about parts for rear disc swap
Old Jul 14, 2006 | 01:43 PM
em2ssm02's Avatar
Default real quick question about parts for rear disc swap
first off i have an 89 civic si.
ok i came across a rather cheap DA that i can get parts from to do the swap.
correct me if i'm wrong but the parts i would need from it are:
the rear trailing arms with everything on it, like the calipers, rotors (ill probably get new ones)
ebrake cable
4040 prop. valve
and i want to get ss brake lines so iwouldnt use the ones on the car. i've heard that ordering the rear brake lines for a 90-91 crx si work.
should i get the MC or brake booster?
please correct me if i'm wrong and only post if you know for sure that those are the parts i need and if i need more than that tell me.
Old Jul 14, 2006 | 01:46 PM
hybridmiklo's Avatar
Default Re: real quick question about parts for rear disc swap (em2ssm02)
The parts you must have are the rear trailing arms and the parts that are on it. You can use the da e brake cables. It is not necessary to take the mc or brake booster but if you have the chance why not. It will only improve your braking.
Old Jul 14, 2006 | 01:54 PM
em2ssm02's Avatar
ok and the brake lines i should get should be for a ......? should it be the 90 or 91 crx si?
Old Jul 15, 2006 | 08:09 PM
em2ssm02's Avatar
ttt easy question come on
GeoMetry
Nov 11, 2015 09:20 AM
mikey1992
May 9, 2010 07:35 AM
racingcrx
Nov 22, 2008 03:43 PM
Chris_
May 30, 2001 04:49 AM
