New Problem, rubbing/grinding... certain rpms
Old Jul 14, 2006 | 01:41 PM
eye.ha8.u's Avatar
Default New Problem, rubbing/grinding... certain rpms
Ok, heres the problem. When I take off in first when I pass around 2000 rpms I hear like a rubbing. Like the sound when your backing plate is rubbing your rotor... almost exact sound but its not that, and it changes through out the rpm range. First gear it will start at 2000 rpms until about 5000 rpms then I think it stops (loud car). In 2nd and 3rd when I hit 3000 rpms it stops but once it hits 4000 rpms it starts again. 4th gear is about the same, 5th I have no idea, too damn loud. I had about 5 min today at work to check it. I opened the hood and rev'd using the throttle. It sounds like it's coming from the tranny area, could be wrong. Any idea?
Also just to add it does it in neutral also, so the car doesnt have to be rolling.
Old Jul 14, 2006 | 04:58 PM
eye.ha8.u's Avatar
Default Re: New Problem, rubbing/grinding... certain rpms (JayDeeEmm)
Also, if a push in the cluth it seems to go away...
Old Jul 14, 2006 | 05:21 PM
JDMCRX05's Avatar
throw-out bearing is bad. gotta pull your tranny and replace it .
Old Jul 15, 2006 | 06:35 AM
eye.ha8.u's Avatar
Default Re: New Problem, rubbing/grinding... certain rpms (JDMCRX05)
Damn, any idea how long I can drive before it makes it gets bad enough where I can't drive it at all?
EDIT: I thought the throw out bearing only made noise when you pressed the clutch in? Because it suppose to sit idle when released. When I press it in it goes away?
Old Jul 16, 2006 | 05:09 PM
JDMCRX05's Avatar
no at idle and in neutral the throw out bearing is free spining when u depress the clutch (as u do when u shift gears ) the throw out bearing stops spining to engage the gear. So in a nut shell if it goes away when u depress the clutch i can guarentee its a throw out bearing. and if it is making noise when your driving that means its getting REALLY bad mine makes noise at idle in neutral but not when im driving. good luck
xkwzt21
Jun 10, 2008 12:58 AM
EJ ITO
May 25, 2007 04:08 PM
GO-FIGHT-KILL
Aug 3, 2006 09:02 PM
SlowestEJ8
14
Dec 29, 2005 03:26 PM
rainydayman
Nov 14, 2005 07:59 AM
