how to put c-clip back on the tranny bearing when reinstalling the tranny case?
Old Jul 14, 2006 | 12:52 PM
flekz's Avatar
Default how to put c-clip back on the tranny bearing when reinstalling the tranny case?
i know i have to pull the whole gear assembly upwards to put the c-clip back in its place but everytime i try to nudge it up it doesn't go high enough, i've tried so many things... am i doing something wrong? is something hitting against something. i know that when i try to put it on i need a few mm's higher to go to get the c-clip on... if anyone has any type of suggestions or pictures i would greatly appreciate it... i need to figure this out asap...
tia
Old Jul 14, 2006 | 05:09 PM
stumpyf4's Avatar
Default Re: how to put c-clip back on the tranny bearing when reinstalling the tranny case? (flekz)
Put a block of wood under the input shaft and then lower the case on it. The case should stand off the table a bit. When you open up the c-clip slightly the input shaft will move up and the c-clip will drop into the groove.
Old Jul 15, 2006 | 09:11 AM
flekz's Avatar
Default Re: how to put c-clip back on the tranny bearing when reinstalling the tranny case? (stumpyf4)
thats the problem its not goin low enough for the cclip to actually go on the groove... i nudge the whole shaft upwards and it doesn't wanna go high enough for it to sit...
Old Jul 15, 2006 | 02:25 PM
JdmEKCivic's Avatar
did you put back the two shims under the main shaft?
Old Jul 15, 2006 | 02:55 PM
IN VTEC's Avatar
Turn the transmission upside-down. If that doesn't do it, then drop it on something soft from a couple inches up.
Old Jul 15, 2006 | 04:13 PM
j spec's Avatar
Default Re: how to put c-clip back on the tranny bearing when reinstalling the tranny case? (IN VTEC)
turn it upside down thats what i did after staring at it in confusion for two hours and trying to think of what i did wrong.
Old Jul 15, 2006 | 04:39 PM
flekz's Avatar
Default Re: how to put c-clip back on the tranny bearing when reinstalling the tranny case? (roma's GSReg6)
ok ive turned it upside down.dropped it from a few inches and still falling short by the smallest margin. Could the c clip be ruined?
Old Jul 15, 2006 | 04:53 PM
IN VTEC's Avatar
Is the clip at least started around the bearing's outer race? There should be ~1/2" gap between the ends.
DEMNTD1
Aug 12, 2005 11:12 AM
IggDawg
Feb 7, 2004 07:34 PM
AlphaKennyWun
Nov 28, 2002 08:29 AM
