Oil Pan Gasket ?
Old Apr 20, 2002 | 07:40 PM
imported204's Avatar
Default Oil Pan Gasket ?
My oil pan gasket is leaking, is it absolutely necessary for me to change it, am i harming the car by not changing it?
Old Apr 20, 2002 | 07:42 PM
Greyout's Avatar
Default Re: Oil Pan Gasket ? (imported204)
only when all your oil leaks out
Old Apr 20, 2002 | 08:10 PM
ELUD THS's Avatar
New User
Default Re: Oil Pan Gasket ? (JDM LUDE)
you definately need to change it, there not that expensive when you do it yourself, if theres a honda slavage yard around you , you can get a used on or just go to your honda dealership to buy one.
Old Apr 21, 2002 | 06:20 PM
Silude93's Avatar
New User
Default Re: Oil Pan Gasket ? (ELUD THS)
If you are just replacing the gasket it is hard to get off. I had to take mine to a machine shop to get the old one off. Oil pans used or new are expensive. Make sure you put the sealants on right (around the crankshaft guides) or you will be having another leak.
Old Apr 21, 2002 | 07:06 PM
Quaalude's Avatar
Default Re: Oil Pan Gasket ? (Silude93)
Hondabond
Old Apr 22, 2002 | 10:15 AM
PrecisionH23a's Avatar
Replacing the gasket is an easy task. drain your oil then Take your cat conv off so you can remove your oil pan. remove the shield on the tranny that covers the 2 oil pan bolts, then remove all the other oil pan bolts. take your old gasket off and trash it. check the oil pan and make sure you dont have any cracks in it and make sure it didnt get banged out of shape. USE A NEW OIL PAN GASKET!!! Also, use honda bond between every other dimple on the oil pan so everything seals up nicely especially near the tranny on the right side. when you put the oil pan back on, you have a certain pattern you should follow when putting the bolts back on. i recommend buying a honda factory manual or the helms. it will explain this process for you. if i had my book with me i would scan this section to you and email it, but unfortunately it is back home 3hrs away. good luck.
Old Apr 22, 2002 | 02:33 PM
boomslang's Avatar
Default Re: Oil Pan Gasket ? (GudeH23a)
Use a new gasket and Hondabond/rtv, it's easy to do and just takes a couple hours.
preludedriva
13
Aug 21, 2007 01:06 PM
lazyxmofo
Aug 16, 2007 09:59 PM
00civicsiboy
Apr 20, 2007 08:27 PM
deconstruct
Jun 18, 2004 01:00 PM
d0nkeyxPunch
May 10, 2002 04:01 AM
