Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
element. airbag system reset
Old Jul 14, 2006 | 06:58 AM
marcin's Avatar
Default element. airbag system reset
i had to move some thing that required taking out the front pass seat. I replaced the seat when i was done but since then the air bag light is on. just wondering if you guys know of a way to reset the system?
thankyou
m.
Old Jul 14, 2006 | 07:43 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: element. airbag system reset (marcin)
To erase the DTC(s) from the SRS unit, use the HDS, or the following procedure.
Make sure the ignition switch is OFF.
Connect the SCS service connector (A) to the yellow MES connector (2P) (B). Do not use a jumper wire.
Turn the ignition switch ON (II).
The SRS indicator will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector (2P) within 4 seconds after the indicator goes off.
The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector (2P) within 4 seconds after the indicator comes on.
When the SRS indicator goes off, remove the SCS service connector from the MES connector (2P) within 4 seconds.
The SRS indicator blinks two times, indicating that the memory has been erased.
Turn the ignition switch OFF, and wait for 10 seconds.
Turn the ignition switch ON (II) again. If the SRS indicator comes on for 6 seconds, and then goes off, the system is OK.
(the connector is the yellow two pin in the drivers fusebox)
Old Jul 18, 2006 | 05:07 AM
marcin's Avatar
Default Re: element. airbag system reset (MooGoCow3)
thankyou, i will give it a try.
marcin.
Old Jul 19, 2006 | 04:19 PM
Jason's Avatar
to save yourself the hassle, next time disconnect the battery before doing anything that you think might trip the computer...
Smok3o3
Feb 22, 2011 05:53 PM
fastfu
Nov 14, 2005 04:31 AM
SaberSix
Acura TL, RL & ZDX
Jul 9, 2004 02:41 PM
rkonfire
May 27, 2004 08:11 AM
Mrivera21
May 28, 2003 03:03 PM
