ls motor knocking on startup
Old Jul 14, 2006 | 02:57 AM
keanevann2005's Avatar
Default ls motor knocking on startup
I just bought 98 ls motor with 52,000 miles...when i start it up in the morning after its been sitting all night it knocks for like 2 seconds...but it sounds like as soon as it gets oil to the head it stops....it runs fine and sounds great all day...it just happens on a truly cold startup. Is my oil pump going out???is this normal for ls motors???
Old Jul 14, 2006 | 05:46 AM
crx_88_si's Avatar
oil level good?>
Old Jul 14, 2006 | 08:10 AM
FULL-REV's Avatar
you should get alittle valve tap on start up in a cold day
Old Jul 14, 2006 | 09:28 AM
DA is best's Avatar
it should always knock because not much oil is in the top of the motor so the oil return line kicks in about 1 to 2 seconds after start up, or something like that
Old Jul 14, 2006 | 09:45 AM
BrooX's Avatar
Default Re: ls motor knocking on startup (keanevann2005)
What kind of fuel are you using?
Old Jul 14, 2006 | 10:26 AM
Default Re: ls motor knocking on startup (BrooX)
i use just regular unleaded
ShortyzKustomz
May 26, 2008 09:47 AM
keanevann2005
Jul 14, 2006 10:29 AM
Vitesse
Jun 30, 2006 01:27 PM
silverb18
Apr 7, 2004 12:31 AM
