IAC ... Advice Needed
Advice needed here .... Im dealing with a crappy Idle after warm ordeal for a month now. No real time to get down and dirty with it, but ... I have a feeling its my IAC. When its cold, its fine. When it s hot, the idle drops to like, 200RPM's, but it runs fine otherwise.
Will there be an issue with running it like this if it is the IAC? I'll deal with the crapola idle until I can replace it next month.
Ok, also, heres the deal ... maybe someone can help point out if its defiantely sounding like IAC:
1) After warm idle goes to crap
2) Putting AC while sitting still will make the idle actually seem worse (however when on consistently while driveing, and stop and go it will appear to be a bit higher but maybe only cuz the engines working harder? no clue.)
3) If I start the car warm, and turn anything on ... like, turn on AC or turn the wheel, the idle drops immediately.
I duno what to do, this is gonna drive me nuts.
Thank you for any advice.
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
