results of my attempt at changing brakelines (its not good)
Old Jul 13, 2006 | 05:57 PM
Sleepy_Red_hatch's Avatar
Default results of my attempt at changing brakelines (its not good)
well i got the two old lines out and i ran one of the new lines from the back to the propvalve...and i stripped one of the fittings on the prop valve. now im at a loss. i have no idea how to get it out. i cant hammer a 9mm in to remove it, theres no room ATALL in there, i can barely fit a rachet in but with little success and im pretty damn sure that the other lines (from the MC and to the front brakes will result in stripping aswell since they look in the same condition...what am i to do?
Old Jul 13, 2006 | 08:06 PM
Default Re: results of my attempt at changing brakelines (Sleepy_Red_hatch)
TTT for a pedestrian
Old Jul 13, 2006 | 09:04 PM
Default Re: results of my attempt at changing brakelines (aallbbeerrtttttt)
since the line was broken, i cut the line off and i used a box end 10mm wrench...you should cee the rust that built up.
Old Jul 13, 2006 | 09:18 PM
egcivic's Avatar
box end isnt the same as the flare not wrench
and you will need the flare nut wrench
http://buy1.snapon.com/catalog...5.JPG
the head on a flare nut wrench looks like that
vice grip the one you have out, i ended up having to do it for mine (gas lines)
and use the flare nut wrench on the rest of them
they shouldnt strip, but still i would be careful
Old Jul 13, 2006 | 09:59 PM
instrument's Avatar
the junkyard igot my prop valve from simply cut the lines, but one line was impossible to remove, i had to take a mini-torch to it.... bt it wasn't attached to the car at the time.....
Old Jul 15, 2006 | 09:14 AM
Default Re: results of my attempt at changing brakelines (egcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivic &raquo;</TD></TR><TR><TD CLASS="quote">box end isnt the same as the flare not wrench
they shouldnt strip, but still i would be careful</TD></TR></TABLE>
yea looks like im going to have to remove the pro valve. sigh
Old Jul 15, 2006 | 09:46 AM
egcivic's Avatar
hey you live and learn
ive almost never done a job where i havent done twice the amount of just extra work
the perks of a 12 year old car
cehcivic15
Suspension & Brakes
Jun 11, 2010 09:49 PM
billyinse
Sep 5, 2007 02:40 PM
Easy Eddy
Aug 18, 2006 01:16 PM
FourthGenHatch
Sep 15, 2002 03:51 PM
onyx00
Jan 14, 2002 09:01 AM
