What tires specs will i need?
im looking to getting some 15" rota slipstreams. what size tires should i be looking keeping close to stock tire diameter...i see lots of 205, will that change my speedometer readings from actual speed cause the tires i ahve on now are 195 on ls mesh. its for a daily drive 99 dc4 stock. planning on future mods. 15x6.5
The accuracy of the speedometer and odometer depends on the tire diameter, which depends on the aspect ratio (the second number of the tire size) as well as the first number.
You can use either 195/55-15 or 205/50-15 on your Integra. 195/55-15 is the same diameter as stock. 205/50-15 is 1.6 percent smaller in diameter and will make your speedometer and odometer read high by that percentage.
Tad
13
Jan 16, 2005 06:40 PM
