car does not crank over..
Old Jul 13, 2006 | 04:50 PM
Honda Crx's Avatar
Default car does not crank over..
ok i just replaced the tranny ooh the car is a 90 civic hatch with a d16z6 i have a 89 si tranny. now the car was running perfect went to work.. went to leave work.. went to start the car nothing.. i have power but no types of cranking.. i replaced the starter the battery has juice the starter signal fuse is fine. tried to pop start it no success. now the one thing im thinking is the clutch ignition switch or whatever it is called.. where is that located and if you have a picture can you please post it.. and if you can think of anything else that it could be please i would like to know your suggestions thank you..
Old Jul 14, 2006 | 06:42 AM
Honda Crx's Avatar
Default Re: car does not crank over.. (Honda Crx)
anybody..
Old Jul 14, 2006 | 06:52 AM
jackinthetrunk's Avatar
the clutch ignition switch is right on the back of the clutch pedal. you might want to check the terminals on the battery. If they are dirty the car would not crank over. Clean all the grounds on the engine bay. Check all the fuses in the car. Maybe the starter just went out?
Old Jul 14, 2006 | 06:55 AM
betonred's Avatar
the most common cause of this problem is the battery ground. This is the wire that goes from the battery negative post to the body of the car, then to the transmission. Unbolt it and clean it really well, also clean the area where it contacts the body and the tranny. Since you just replaced the tranny make sure you remembered to reconnect the wire to the tranny. I also upgraded to a better thicker wire when i had this problem and it worked like a charm.
Old Jul 14, 2006 | 07:00 AM
Honda Crx's Avatar
Default Re: car does not crank over.. (betonred)
umm the car was running perfect i will get there to clean the grounds and all that now i what does the clutch ignition swtich look like.
Old Jul 14, 2006 | 07:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Crx &raquo;</TD></TR><TR><TD CLASS="quote">umm the car was running perfect i will get there to clean the grounds and all that now i what does the clutch ignition swtich look like. </TD></TR></TABLE>
its very small, located on the top end of the clutch pedal. you cant miss it.
Old Jul 14, 2006 | 08:26 AM
Honda Crx's Avatar
Default Re: car does not crank over.. (jackinthetrunk)
i would to get a picture of this object.. i need to get a ride to my car and mess with it..
Old Jul 14, 2006 | 10:24 AM
Honda Crx's Avatar
anybody else?
Old Jul 14, 2006 | 11:15 AM
saikouEF8's Avatar
main relay...
Old Jul 14, 2006 | 12:26 PM
Honda Crx's Avatar
Default Re: car does not crank over.. (saikouEF8)
you think because i was hearing a fast clicking noice (relay) under by the fuse box.when i was trying to start the car.. but im not sure on how the relay goes bador how it sounds when it goes bad..
Old Jul 14, 2006 | 02:50 PM
Honda Crx's Avatar
alright who thinks its the main relay.. lets take a poll on which thing i should check out..
Old Jul 14, 2006 | 04:36 PM
you should search about it. There are hundreds of threads just like this one. It will give you more ideas and even might find some symtoms very familiar to you.
Old Jul 14, 2006 | 06:19 PM
Honda Crx's Avatar
bump..honda-tech meet tommorrow and im trying to get there..
Old Jul 15, 2006 | 08:56 AM
Honda Crx's Avatar
well its not the main relay.. all the connections are good. just leading back to the starter.. any other suggestions please.
Lao17
Jul 17, 2017 01:10 PM
94turbo
11
Jul 3, 2009 05:02 AM
EJ8ronnie
Oct 29, 2007 04:14 PM
KyleVA
Sep 6, 2006 03:13 AM
Rickcrx
Apr 18, 2004 08:47 PM
