What causes wheel hop?
Old Jul 13, 2006 | 02:31 PM
Rocking's Avatar
Rock With It
Default What causes wheel hop?
I recentley change my tires to some AVS ES100's and Shifting @ 8500 RPM causes my car to hop pretty bad. How do I reduce this ? MY car is a Stock 99-00 Civic SI with I/H/E
Old Jul 13, 2006 | 02:34 PM
G2 Speed's Avatar
Default Re: What causes wheel hop? (Rocking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocking &raquo;</TD></TR><TR><TD CLASS="quote">I recentley change my tires to some AVS ES100's and Shifting @ 8500 RPM causes my car to hop pretty bad. How do I reduce this ? MY car is a Stock 99-00 Civic SI with I/H/E</TD></TR></TABLE>
the engine moving causes wheel hop
those engine dampners... help
http://www.getnrg.com/nrgdamper_bl.php
or traction bars
http://www.modacar.com/product...DATRB/
those products are just examples ;P
edit: these are good either way
The Z10 Radius Arm Traction System can offer your car increased durability, improved traction, lower 60' times and will completely eliminate wheel-hop. It's specially engineered design provides extra stability, enabling you to not only launch harder but to retain complete suspension travel, no binding! Suitable for both road and drag racing, Z10's Radius Arm Traction System retains factory ground clearance and allows for caster adjustment.
-Completely Eliminate Wheel-hop!
-Bolt-On Traction Uses Factory Bolt Holes
-Launch Harder, Lower 60’ times
-Retains Complete Suspension Travel—No Binding
-CNC Machined Components, TIG Welded Crossmember
-Retains Factory Ground Clearance
-Allows for Caster Adjustment
edit 2: I think wheel hop has to do with the engine mounts also, you could try putting 3m window weld, where the mounts go I have to find that thread off of clubsi... except it seems like there down
Old Jul 13, 2006 | 02:42 PM
philosofy1's Avatar
stiffer engine mount will reduce wheel hop, but poly bushing(for your suspension) would help as well.
Old Jul 13, 2006 | 04:09 PM
schardbody's Avatar
soggy mounts or not having the a/c bracket tq mount installed is the problem. if it occurs during shifts. traction bars will help if it does it bad at launch, but stiffer mounts help the most.
Old Jul 14, 2006 | 12:34 AM
SuperSi's Avatar
Very informative post
type B16
Oct 31, 2006 07:29 AM
b16a27
Mar 4, 2005 09:18 AM
pydc2r
Aug 3, 2004 10:55 PM
elevatethis
Jun 2, 2003 09:22 AM
