Weird no start problem. Injectors.
Old Jul 13, 2006 | 12:03 PM
CLE's Avatar
CLE
Default Weird no start problem. Injectors.
Ok car has been starting fine but all of a sudden yesterday it would not start.
If I spray something flammable into intake the car starts fine, which means no fuel.
However fuel pump is priming(not main relay) I pulled the fuel filter in line and turned key to on position and fuel came out(rules out fuel pump.) So the only thing it could be is the injectors, I pulled the fuel rail and of course gas was in it, came out when I pulled injectors.
What I want to know is what should I check regarding the injectors not spraying. I'm 100% positive not all injectors would go out at the exact same time so im thinking it has to be wiring somehow or some ground.
Anyone know?
Old Jul 13, 2006 | 02:25 PM
CLE's Avatar
CLE
Injector resistor box, was not connected all the way, problem fixed.
95CivicDx51
May 29, 2009 09:15 AM
slamedcivic
Nov 2, 2006 02:49 PM
allmotor.net
Sep 27, 2004 11:57 AM
RexedM3
Jul 5, 2004 11:46 AM
Sinner
Jun 6, 2003 02:25 PM
