90 - 93 accord f22a1 to 92-96 prelude f22a1
F22A1/4 are exactly the same no matter what car. Only difference is the Prelude ECU has a slightly more aggressive map vs the Accord ECU which is set for better milage. The F22A6 is the same block wise, but uses a dual stage intake manifold (like the H23 and H22), and has an ever so slightly more aggressive cam (5hp difference). Either way, any of those 3 engines will drop right in a bolt up, but the A6 would require a different ECU to activate the secondary intake runners
