No spark on B18cR...
Old Jul 13, 2006 | 11:04 AM
APCforthewin's Avatar
Default No spark on B18cR...
I just swapped my 96 B18cR into my 99 civic hatch, and no im not getting spark. Are there ANY sensors that must be working/reading in order for the dizzy to fire? Are there any major grounds for the dizzy that i may be overlooking? Im using a cx harness form the original D16y7. Anyone with this scenario???
Old Jul 13, 2006 | 02:39 PM
I Have an STD's Avatar
wrenchin'
Default Re: No spark on B18cR... (APCforthewin)
what ecu are you using? if you try to use the ecu from the 96 spec r, it wont work, you need an obd2b ecu or an obd2b->obd2a conversion harness. the main grounding points are the valve cover, tranny, and thermostat housing.
Old Jul 13, 2006 | 07:20 PM
Default Re: No spark on B18cR... (I Have an STD)
Sorry i forgot to add that i DO have a conversion harness B to A. I also do have the jdm p73 ecu.
kruthles
Feb 5, 2004 06:00 AM
busmcrs
Jan 9, 2003 09:49 PM
tonyxcom
Aug 15, 2002 04:59 AM
