Oil Cooler Update....changed the oil!
Hey Gang,
I got around to changing the oil in the car today, as well as the brake pads on all corners. Anyway I wanted to let you know the trick of poking a hole in the oil filter and blowing into it with an airhose worked like a champ. I was able to "pump" all the oil out of the filter and most of the lines. I added the fresh juice, primed the system, and now I am back in business.
The cooler does add a bit more time to the oil change, but the results are well worth it. My temps were below 250 degress all last weekend....even while chasing Shultz during the time trial. All you R owners that track your cars...get a cooler!!!!!!
Ciao'
Ciao'
