gas grades
Old Jul 13, 2006 | 09:11 AM
racetowin's Avatar
Default gas grades
This might be a stupid question, but does anyone know what octane grades japan has for fuel? I have a jdm h22a engine in my race car and thinking about using higher octane fuel. I know it does not matter if you do not have the compression, but the jdm h22's have a higher compression than a usdm. Can anyone help me?
Old Jul 13, 2006 | 09:13 AM
hu's Avatar
hu
Not sure about the gas in Japan... but you should use the best octane you can. 91 or 93.
Old Jul 13, 2006 | 09:20 AM
PiNoY_BB6's Avatar
Default Re: (hu)
JDM motors need at least a 93...
but 91 would do... since not all places have higher than that... only luckier places get higher than 91... lol
Old Jul 13, 2006 | 09:22 AM
petern101's Avatar
Default Re: (PiNoY_BB6)
yall do realize japan uses different standards for gas right?
their "100 octane" isn't equal to 100 octane over here.
i've ran 91 / 93 in my h22a and doesn't do anything (on stock timing)
so just put premium
Old Jul 13, 2006 | 09:26 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: gas grades (racetowin)
h22> race car???? okay anyway...91+ ocatne is the soup of the day....JDM 10:6.1 CP...USDM 10:1 anything lower than that you run the risk of detonation and that eats away pistons...who the hell gives a **** bout japonese gas?? were in america homie!! lol
Old Jul 13, 2006 | 09:28 AM
racetowin's Avatar
Default Re: gas grades (I got the CD5 Jeebies!)
the reason why i care is because i have 110 race fuel. i'm just wondering how to mix it or if i should just run it straight.
Old Jul 13, 2006 | 09:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racetowin &raquo;</TD></TR><TR><TD CLASS="quote">the reason why i care is because i have 110 race fuel. i'm just wondering how to mix it or if i should just run it straight.</TD></TR></TABLE>
wow I hope you tune for it..otherwise your wasting money on good gas...car will burn cleaner though
Old Jul 13, 2006 | 10:29 AM
Speedra500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">
wow I hope you tune for it..otherwise your wasting money on good gas...car will burn cleaner though</TD></TR></TABLE>
no, it will just burn more expensive gas, premium will be fine in your jdm h22 "racecar" unless your motor has had poor maintenance and developed hotspots on the head, the only benefit you will see is a decrease in weight from your wallet
Old Jul 13, 2006 | 10:39 AM
petern101's Avatar
Default Re: gas grades (Speedra500)
lol, i didn't see the racecar part.
maybe you should concentrate on racing instead of worrying about trivial stuff like this. most of all the actual race preludes run premium
Old Jul 13, 2006 | 10:43 AM
92piece's Avatar
Default Re: gas grades (petern101)
does it matter if you use regular unleaded (87)?
Old Jul 13, 2006 | 11:19 AM
maks's Avatar
Default Re: gas grades (92piece)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92piece &raquo;</TD></TR><TR><TD CLASS="quote">does it matter if you use regular unleaded (87)?</TD></TR></TABLE>
You "can" use it, but it's not good for your car, since the H22 engine was designed to run on 91. Running lower octane means that you are more likely to ignite before the timing is right... This is why we have knock sensors, however, in the long run, it is still bad. Running on lower octane also decreases performance.
If you'd like to actually learn something (OP included), check these links out:
http://auto.howstuffworks.com/question90.htm
http://en.wikipedia.org/wiki/Octane_rating
Old Jul 13, 2006 | 12:30 PM
92piece's Avatar
Default Re: gas grades (maks)
what about h23a1--just as bad?
Old Jul 13, 2006 | 12:36 PM
98vtec's Avatar
moderator emeritus
its a non vtec motor. U can run low grade gas in it.
all the Vtec motors are to run premium fuel at all times.
Old Jul 13, 2006 | 12:41 PM
Eddiebx's Avatar
Default Re: gas grades (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">its a non vtec motor. U can run low grade gas in it.
all the Vtec motors are to run premium fuel at all times.</TD></TR></TABLE>
actually didnt the h23 need premium tooo? i forget, but tahts what i remember reading, but i never owned one so i wouldnt konw.
Old Jul 13, 2006 | 12:44 PM
Brown-tec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">all the Vtec motors are to run premium fuel at all times.</TD></TR></TABLE>
what bout I-VTEC motors?
Old Jul 13, 2006 | 01:03 PM
cgo_62's Avatar
you could mix your 110 with 91 to get 93 if you wish. it's a ratio so you'll have to formulate an equation to figure out the average. for example, i can't get 93 here in california but there are a few gas stations that sell 100.
1gallon 91 + 1gallon 91 + 1 gallon 91 + 1 gallon 100 = 373
373 / 4 (total gallons) = 93.25 octane (3:1 ratio of 3 part 91 and 1 part 100)
if you want 93 from your 110: your ratio is about 9:1
it'll be 9 gallons of 91 per 1 gallon of 110 = 92.9 octane
**edit** "race fuel", as you mentioned, may have other chemicals in it which renders the above formulas useless. most "race fuel" bottles recommend that your use it with a full tank of gas.
Modified by cgo_62 at 2:14 PM 7/13/2006
Old Jul 13, 2006 | 01:12 PM
b*saint's Avatar
Default Re: gas grades (cgo_62)
Japanese reg fuel is like racing gas. Use 93 or higher on JDM engines.
Old Jul 13, 2006 | 01:54 PM
shutta's Avatar
if your gauge cluster says use premium unleaded fuel only, do it. unless your car is tuned to use race gas, it's not really going to benefit. just as using premium on low compression low output motors like a toyota corolla, it pretty much a waste as well, it's not what is designed to be burned.. one kid told me he used premium on his accord because it burned slower and he got better mileage, yeah he's stupid.
i'd say you have a better chance of becoming a faster driver in yoru race car by driving it than pondering the race gas sitting in you garage. ever see the sport compact car races where regular guys race their own cars time attack style againt pro racers? see some of those time differences? that's because of practice not better gas. sorry if this sounds rude.. i'm not meaning it to be
Old Jul 13, 2006 | 02:15 PM
92piece's Avatar
Default Re: gas grades (Eddiebx)
yea- it says to use only premium, but i have used both premium and regular and i cant tell much difference
Old Jul 13, 2006 | 03:31 PM
mmmtrbolude93's Avatar
Its funny that people are doggin on the racing aspect of this but a lot of people race circle track with 3rd gens w/ h22
Old Jul 13, 2006 | 04:10 PM
petern101's Avatar
Default Re: (mmmtrbolude93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmmtrbolude93 &raquo;</TD></TR><TR><TD CLASS="quote">Its funny that people are doggin on the racing aspect of this but a lot of people race circle track with 3rd gens w/ h22</TD></TR></TABLE>
who's doggin? its just somewhere along the lines of
"if you have a "racecar" questions like these are trivial" per se.
i mean honestly, race car drivers shouldn't be asking questions like these. and i have yet to see a 3rd gen at a hpde event. just 5th gens (even real race spec 5th gens) and a couple of 4th gens (me included)
Old Jul 14, 2006 | 10:04 AM
racetowin's Avatar
Default Re: (petern101)
That's where your wrong. Hell yes race car drivers should be asking questions like this. I been racing honda's on dirt tracks for years. Its the little things that make you win. You are always trying different things. I have won back to back championships and on my way to a third on the little things. I have never had a jdm motor until this year, thats why i ask. And for h22's being over rated, mine is stock and wooping turbo eclipse ***. You always got to be on top of your game pal.
Old Jul 14, 2006 | 10:13 AM
smo0th's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiNoY_BB6 &raquo;</TD></TR><TR><TD CLASS="quote">JDM motors need at least a 93...
but 91 would do... since not all places have higher than that... only luckier places get higher than 91... lol</TD></TR></TABLE>
Hehe I must be lucky then because we have 93 down here.
Old Jul 14, 2006 | 05:04 PM
Default Re: (smo0th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">
i mean honestly, race car drivers shouldn't be asking questions like these. and i have yet to see a 3rd gen at a hpde event. just 5th gens (even real race spec 5th gens) and a couple of 4th gens (me included)</TD></TR></TABLE>
well my buddy and his dad race a 90 accord and a 3rd gen lude on circletrack at kil kare...
Its not like I am trying to make stuff up
Old Jul 15, 2006 | 09:24 AM
racetowin's Avatar
what motors do they run?
