Need to bleed brakes after pad install?
Old Apr 20, 2002 | 03:44 PM
onyx00's Avatar
Default Need to bleed brakes after pad install?
I need to take my brake pads out and put some stuff on the backs of the pads to stop the squeaking. After doing this do I need to bleed the brake system? Will it be necessary?
Old Apr 20, 2002 | 03:46 PM
Rob :190:'s Avatar
Default Re: Need to bleed brakes after pad install? (onyx00)
id say so.
Old Apr 20, 2002 | 03:47 PM
AssPenny's Avatar
Default Re: Need to bleed brakes after pad install? (Brian Spilner 1035)
It's dosen't hurt, thats for sure.
Craig - Who has swaped pads with out doing a bleed due to his *** being lazzy.
Old Apr 20, 2002 | 04:00 PM
N24RE's Avatar
Not if you do it routinely any ways. I change pads about 8 times per year. When I go back to the street pads from my track setup I don't bother with it. As long as you end up putting on thicker pads than you take off,,,ie you have to force fluid OUT of the calipers....you don't have too.
On the other hand if you don't bleed them for track stuff several times per year, then yes I would bleed the system
just my 2 cents
Old Apr 21, 2002 | 06:39 AM
Back in Black's Avatar
Rather OG
No, it's not necessary.
However, it's never a bad idea...
216.226.142.95:27016
10
Apr 29, 2004 07:11 AM
OEMaccord
13
Sep 20, 2002 11:08 AM
CD8
Jun 10, 2002 04:34 AM
onyx00
Nov 20, 2001 05:51 PM
MattD@Stoptech
15
Sep 4, 2001 05:50 PM
