VSS Help! 1991 CRX w B16a
Old Jul 13, 2006 | 07:43 AM
BlackLudeSi's Avatar
Default VSS Help! 1991 CRX w B16a
Like title says, I have a cable speedo n trans but i need a VSS signal to tap into my navigation system. Is there any way to get a signal short of switching to a VSS trans with guage cluster?
EDIT found through shearch that the B7 red/yellow wire from guage cluster to ecu should do the trick
Modified by BlackLudeSi at 1:28 PM 7/13/2006
Old Jul 14, 2006 | 06:52 AM
Default Re: VSS Help! 1991 CRX w B16a (BlackLudeSi)
Bump, anyone confirm that its the red/yellow wire in guage cluster for the vss signal on a cable speedo?
Old Jul 15, 2006 | 05:12 PM
JohnnieChimpo's Avatar
The info I have is a little vague. The book says there are two screws near the speedo cable on the back of the cluster and they have continuity 4 times per revolution of the speedo calbe. You might search for the pinout of the OBD0 ECU I'm 99% certain the ECU reads the speed. Once you find the pin for the ECU plug you can tap that wire.
Sorry I'm not more help but I converted to electric VSS so my wire is easy to find
Good luck with your project.
What Navigation did you get?
Old Jul 16, 2006 | 06:28 AM
Default Re: VSS Help! 1991 CRX w B16a (JohnnieChimpo)
http://www.boosted.org/obd0.php?page=obd0
I actually dug around for 30 minutes and the best info I could find was the VSS ties to B16 slot on the OBD0 ECU harness.
Now you have the info. Navigate.
Old Jul 17, 2006 | 07:35 AM
cool thanks alot guys, btw its a eclipse navi
michael O
91
Apr 18, 2011 08:04 AM
4LugR
Jan 22, 2011 07:02 PM
civickid03
Jul 20, 2006 06:03 PM
2kTeg
Mar 30, 2005 04:56 AM
HatchBox
Sep 20, 2004 08:32 PM
