EF too light when rear seats/stereo components removed?
When I did my Type R swap, I had my rear seats in place, and my sub, amp, and 6by9s in the rear. It was a fairly stable platform, and I could really throw it into sweeping turns, like highway cloverleafs. I recently had the car painted, and had the rear seats, and the stereo system removed. The difference in handling is freakish- if I make a sharp turn, the car feels tippy, like the rear end wants to swing around. Makes for some white-knuckle handling- have any of you EF owners with Integra motors swapped in experienced this phenomenon if you removed too much weight from the rear of the car?
You need a bit of weight in the back. I keep the battery in there and it seems fine. If you are running some stiff dprings and some sticky tires (RA1s for example) you shouldn't have to worry, it's just a feeling the car will stick. If not, then you can upgrade even more with some bushings, maybe a sway bar? Stiffing up the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">I'm buying a new one soon. Forget which company. Getting a good deal cause it's a friend, but apparently it stiffens the **** out of the rear.</TD></TR></TABLE>
Maybe Suspension Techniques? I noticed a big difference by swapping my Si sway bar with an ST bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doitdub »</TD></TR><TR><TD CLASS="quote">
Maybe Suspension Techniques? I noticed a big difference by swapping my Si sway bar with an ST bar.</TD></TR></TABLE>
That's it. 150$ CDN fresh out of the box, comes will all the hardware, how could I pass that up?
gyrmaersk
Suspension & Brakes
14
Aug 4, 2006 05:35 PM
gyrmaersk
Jun 14, 2006 11:57 PM
