rattling sound at 3000 rpm
Old Jul 12, 2006 | 11:53 PM
Singlefury's Avatar
Default rattling sound at 3000 rpm
i have this problem with my 99integra gsr. When i hit 3000rpm it gives a rattling sound like somting is loose. it has it in all the gear when it hit 3000 rpm.
Old Jul 13, 2006 | 12:50 AM
lsvtek's Avatar
Default Re: rattling sound at 3000 rpm (Singlefury)
check your exhaust, and the part that connects to your headers may be those
Old Jul 13, 2006 | 06:46 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Probably something with the exhaust, where does it sound like it's coming from?
Old Jul 13, 2006 | 06:47 AM
HONDA RR's Avatar
Check your exhaust and your cat. Maybe there is a bolt that is loose causing the rattle.
Old Jul 13, 2006 | 06:53 AM
90dateg's Avatar
could be the heat shield is coming loose -
Old Jul 13, 2006 | 09:05 AM
Whiskeydcks45's Avatar
Default Re: (90dateg)
I had the same thing happen to me and it was the exhaust manifold cover thats what i would start with
Old Jul 13, 2006 | 09:15 AM
taquitoman33's Avatar
your exhaust might have a crack in it.... if so you can buy a clamp for it anywhere make sure u get the right size
Old Jul 13, 2006 | 09:25 AM
jarrYd's Avatar
i dont think its anything serious. i had the exact same thing happen to me and all i know is it was just a loose heat sheild.
Old Jul 13, 2006 | 09:13 PM
youre_scum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dateg &raquo;</TD></TR><TR><TD CLASS="quote">could be the heat shield is coming loose - </TD></TR></TABLE>
Old Jul 13, 2006 | 11:36 PM
da9pwnsu's Avatar
ive had that problem, check ur cat
edit: ppl on ht also told me it was heatshield, but check ur cat it may be bad
Old Jul 16, 2006 | 09:59 AM
Singlefury's Avatar
ok i check everywhere. i took out steal cover for the whole exhust system. it still sound the same.
Old Jul 16, 2006 | 10:20 AM
Fat Chick Magnet's Avatar
maybe the heat sheild..mine around 4000rpm makes a rattle sound and its the heat sheild.
Old Jul 16, 2006 | 11:20 AM
davidluko's Avatar
Check the bolts between the header and cat, mine rattled also around 2.5-3k rpm and that's what it was (long story short, the bolts bent and stretched causing the header to come a little loose from the cat, but yours might just be loose).
Old Jul 16, 2006 | 01:17 PM
EGY8's Avatar
Default 99 gsr
i had the same problem with my 99 gsr at about 60,000k. it was the piece between the header and the cat. honda said it happens sometimes if you live in the northeast due to salt used on the roads in the winter. i replaced the entire exhaust system for not much more than what honda wanted for just that piece (a piece).
Old Jul 16, 2006 | 06:11 PM
Singlefury's Avatar
i took out all the heat sheild and the header heat sheild and test it, same problem. it sound like its coming from the manifold bolt. i hand tight them and still same problem. at 3000 it sound like a turbo.
Old Jul 16, 2006 | 06:58 PM
dudefella's Avatar
Default Re: (Singlefury)
I had an extremely annoying rattle at ~3200rpm... could only hear it when accelerating slowly through 1st and 2nd. Heat shield was loose.
Old Sep 1, 2011 | 08:37 PM
accord00-h22a4's Avatar
had the same problem, but i figured out the problem to late.. it was a bracket they call the flange... its right behind the engine where the headers connect to the cat.. well on mine it ripped off n made a hole on my headers.. whacckk...
beastman@
Sep 25, 2007 04:48 PM
dhatb0ijohnny
10
Jul 10, 2007 06:24 PM
91(si)hatchey
Sep 28, 2006 12:22 AM
serious
May 5, 2004 08:58 AM
Qikcivic
Oct 12, 2003 10:07 PM
