Konig Helium Lug Nuts
I was just woundering if you can use OEM lug nuts/locking nuts on the Konig Heliums. Can I use them or do I have to but tuner lugs? There going on a CRX Si and are 15" if that matters. Thanks!
Correct me if I am wrong, but the seating of the lugs is different for those wheels, so you should really get some tuner lugs - as the OEM ones won't "fit" quite right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnthr30 »</TD></TR><TR><TD CLASS="quote">Correct me if I am wrong, but the seating of the lugs is different for those wheels, so you should really get some tuner lugs - as the OEM ones won't "fit" quite right. </TD></TR></TABLE>
That's correct.
The Konigs should require 60-degree tapered (conical) seat lug nuts like most other aftermarket wheels.
That's correct.
fms1day
May 24, 2006 09:41 AM
TegoDC5
11
Oct 30, 2005 10:38 AM
