91 CRX SI Not Starting
I searched for "wont start" "wont run" etc etc..
Info: 91 CRX SI
Stock Motor
No mods
Ran fun up until now..drove it to work and parked it.... went and did some work... got out and pulled my crx into the shop...took my front plate off and then went to start the car up... it'll crank but not turn on... so I looked for grounds and all the ones I saw were okay.... took the plug out and looked at it.... then I put the plug back in and unhooked a wire from the dizzy and held it close while a buddy cranked it... no spark....
I checked all my fuses under the dash...
Where should I look to fix my no spark problem?.... it ran perfect up until I parked it in the shop bout a hour ago...
thanks
Info: 91 CRX SI
Stock Motor
No mods
thanks
An easy way to check this is if when you turn the car on, you hear a click from the drivers footwell. The best way to check for spark is get a spare plug and unhook a wire, put the plug in, and ground the body of the plug to the block or other grounding point. If you get a spark, then obviously you have spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 »</TD></TR><TR><TD CLASS="quote">An easy way to check this is if when you turn the car on, you hear a click from the drivers footwell. The best way to check for spark is get a spare plug and unhook a wire, put the plug in, and ground the body of the plug to the block or other grounding point. If you get a spark, then obviously you have spark.</TD></TR></TABLE>
Tried that.. no spark...
I'll check for the main relay...
It's throwing a code... it flashed 6 times... paused 10 times.. paused 15 times.. then back to 6 ... then 10... etc etc....
I don't know what that means.. guess Ill google it.
So the main relay is a little black box correct? I took it out.. looks fine but I'm unsure of how to check to see if it actually works....
Putting it back in.. resetting the battery and gonna try to start it...
What should I check on my dizzy?
https://honda-tech.com/zerothread?id=1555833 pic of a main relay in there...
so you have no spark, when you crank it does it backfire? check your coil and igniter it's inside the distributer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1555833 pic of a main relay in there...
so you have no spark, when you crank it does it backfire? check your coil and igniter it's inside the distributer.</TD></TR></TABLE>
No spark, cranking and it does not backfire....
So take my cap off and just hceck the igniter..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexShop »</TD></TR><TR><TD CLASS="quote">
So take my cap off and just hceck the igniter..</TD></TR></TABLE>
Inspect it, might want to replace it, i'd look for a used one if i were you. by the way are you getting any cel codes? (check engine light)?
Inspect it, might want to replace it, i'd look for a used one if i were you. by the way are you getting any cel codes? (check engine light)?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexShop »</TD></TR><TR><TD CLASS="quote">Are these right?
6 Coolant temperature sensor or circuit
10 Intake air temperature sensor or circuit.
15 No ignition output signal - possible faulty igniter.
igniter can cause it and so can the coil. or you can bust out with a voltage meter and start seeing which one has no/low power. i forgot wat the avg volts were i'm pretty sure their in here on honda tech somewhere
So I sat and played PS2 for a while after I took apart the dizzy and what not.... and it wouldnt start even after putting it back together..
There's a sensor near the wiper motor thing (pass side almost by the firewall) that I unplugged and plugged it in the other way (upside down or right way up , not sure if it matters) but it started right up.... it's still throwing the 1st two codes though.. but it runs fine...? =/
ElijBurgos
Aug 28, 2014 06:43 PM
