Code 4 - Worth Fixing? Affect Performance?
My car just started throwing a code 4, I randomly looked at the ecu and it was flashing code 4, check engine light doesnt come on though and I dont really notice any differences anywhere
What affect does code 4 have? Why is it being thrown? Worth fixing?
The car is an obdo 88 crx with a d16a6 - turbo
Thanks
Thanks
I would highly recomment any code that represents something inside of your distributor.
my cyp is bad, and my car stutters and has a roaming idle
well if your smart and read what it says about code 4 you would know that you should fix as soon as possible or els your car will run like ****. if you have any car knowledge you would konw this. in my opinion any code is worth fixing.
Well whatdya ******* know, car did a ew missfires and pops/stutters on my way to and from work
Must mean something after all!
Code 4? Crank position sensor...that's eh...pretty good one to clear incase your timing belt jumps a notch or something...but whatever, it's only and engine it won't hurt performance!
PINKS
11
Jul 13, 2006 06:00 PM
