** engine reving. ** problem help
When is start my car each monrning it revs from 1500 to 3000 and drops back down it does this until the engine is *HOT* and then settles at 1500. i change new radiator and hoses. and fix my vaccum hose too. doesnt Help. where is the IAC located. can that be the problem? Help please
i think i found the problem it's a Gasket leakage off the Throttle body. cause when i test for codes i had nothing. but i did the gasket test on the throttle body and im sure of it it's that. cause change all my hose even my radiator since it's kind of old.
be sure to check your throttle body gasket . tis is to anyone with a problem like this.
