Anyone running 15"x8" w/+0 offset?? Please give me some advice!
Old Jul 12, 2006 | 05:16 PM
OCjuice's Avatar
Default Anyone running 15"x8" w/+0 offset?? Please give me some advice!
Hi all, I am planning on buying a set of wheels size 15"x8" w/+0 offset and was wondering if anyone on here is running this setup for your EG or EK? I need to know if it will fit without having any problems/rubbin. My car's fenders have been rolled before so that 17" rims can fit while car is slammed. Please any suggestions or advice would help. Thanks in advance.
Old Jul 12, 2006 | 05:32 PM
kiddcarbuff's Avatar
i doubt that offset and width will worth w/out fender flares
Old Jul 12, 2006 | 06:04 PM
Voyage34's Avatar
Default Re: (kiddcarbuff)
that setup will be wider than a stock setup by ~3.5" per side. wider as in track width not wheel width.
im guessing that will stick out beyond the fender by a considerable amount so even with rolled fenders its very likely you will rub very very often.
ninja edit: unless of course you maintain a stock ride height with substantial spring rates so you wont compress more than fender gap. and even then you may still rub with wheels turned.
Old Jul 12, 2006 | 07:34 PM
OCjuice's Avatar
Default Re: (Voyage34)
what if you ran 195-45-15 tires, would it still be rub you think?
Old Jul 12, 2006 | 07:39 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Anyone running 15"x8" w/+0 offset?? Please give me some advice! (jkhang)
i run 15x9's with a 12mm offset, and believe you me that you will have clearance issues without major fender mods.
Voyage34's Avatar
Default Re: (jkhang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkhang &raquo;</TD></TR><TR><TD CLASS="quote">what if you ran 195-45-15 tires, would it still be rub you think? </TD></TR></TABLE>more than likely, because the wheels themselves are sticking so far out. because of the width and offset, the wheels themselves stick 3 1/2" further out than your stock wheels. i know on my car that would have been a good couple inches past the fender, which if the suspension is compressed enough it would rub regardless of what size tires are on there. also, 195/45/15 isnt the most common of sizes, a blanket search on tirerack turned up 2 results, neither of which example in that size was approved for an 8" wide rim.
Old Jul 12, 2006 | 07:41 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">i run 15x9's with a 12mm offset, and believe you me that you will have clearance issues without major fender mods. </TD></TR></TABLE>
Pics?
Old Jul 12, 2006 | 07:44 PM
Rodney's Avatar
Default Re: (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Pics?</TD></TR></TABLE>
look in my sig, i can't do all the legwork for ya...
Old Jul 12, 2006 | 08:00 PM
SovXietday's Avatar
Default Re: (Rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">look in my sig, i can't do all the legwork for ya...</TD></TR></TABLE>
Who would have thought.
Goddamn, and I complain about my 7" wheels not tucking well.
gg emerican
Honda Civic (2006 - 2015)
Mar 28, 2009 08:08 AM
islander76
May 1, 2007 09:41 AM
ct991
Honda Civic (2001 - 2005)
Jan 14, 2007 03:07 PM
juice91si
Mar 21, 2006 06:59 PM
ActiveAero
Feb 12, 2005 02:41 PM
