Zex kit blew my engine...
Ok so i just had a zex kit on my gsr... 55 shot of dry nitrous... I went out last night to go test after installing some bkr7e-11 spark plugs and checkin all the lines... So my first run was in second gear at 4000 rpm to 7.5k and then turned off... 15 minutes later another identical run... i turned it off... picked up my friend to suprise him... a third second gear pull from 4000 rpm... it worked fine, however as i found my way to the empty access road about 3 minutes later i put it in second from 4000 rpm and nailed it almost to the top of third when my car seemed to a hit a rev limiter at 6000 rpm??? As you can guess my engine began luggin (warbling like a wrx) and i took it home, diagnosed it today with a 71 and 72 code... (1 and 2 cyl. misfires) What i dont understand is how could this happen? I thought i had everything right??? It emptied the bottle in those runs, none i which even came close to 10 seconds each...
Here are the plugs (used for about 10 miles)
Here is the reason it blew (No jet installed)
Footnotes: Had my nitrous installed, a jet was forgotten, my motor is blown...
Modified by 97 GSR at 4:12 PM 7/14/2006
should have went wet. Did you double check the lines after the first use? when double checking after an install, many dont realize pressure still has not gone through half the lines. I ran a zex 75 wet shot for a total of 2 years, on two different cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">Try checking, or changing out the plugs yet?
What octane were you running on?</TD></TR></TABLE>I did... i switched to colder plugs and i was runnin supreme (91) as always...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff »</TD></TR><TR><TD CLASS="quote">were you low on gas? this happened to my boys 97 gsr when we were pounding on it w/ like NO gas, it threw a CEL and it would rev past 6k</TD></TR></TABLE>I definately wasnt low on gas cuz i filled up after the first run... I did however turn the nitrous on first, then off while it was sitting (car off) to check for leaks (to put the plugs in) and then back on while i started it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">Check the plugs, they're prolly melted.</TD></TR></TABLE>Im gonna pull 'em tonight or tomorrow... ill post pics
My guess would be that it is a fuel related issue. Pull your plugs and check them out. Was your kit new or used? Did you have the vaccum lines on correctly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry »</TD></TR><TR><TD CLASS="quote">Did you ever have it tuned since you put on the nitrous? Dont you need to add more gas (enrich the af mixture) when ever you add nitrous?</TD></TR></TABLE>I know ive heard and know of people (the guy i bought it from) and others that with a 50 shot you dont need anything but colder plugs (which i had)
(Bkr7e Plugs) in order 1 2 3 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">Wow you ran uber-lean. Melted piston rings...</TD></TR></TABLE>Im goin to school for automotive tech this fall so im thinkin i should just use this as an oppurtunity to pull apart the engine.. Should i even attempt it? Or is the motor that gone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">Wow you ran uber-lean.</TD></TR></TABLE>
yup
yup
i say lean also..have you tried replacing the plugs and see how it runs? you might have lucked out and only melted the plugs..ive burned a couple spark plug ground straps when i was "tuning" my old wet setup..the engine was still fine after though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">have you tried replacing the plugs and see how it runs? </TD></TR></TABLE>
x2, see if it's beyond just the plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">i say lean also..have you tried replacing the plugs and see how it runs? you might have lucked out and only melted the plugs..ive burned a couple spark plug ground straps when i was "tuning" my old wet setup..the engine was still fine after though</TD></TR></TABLE>
Yeah, that crossed my mind... It did run home, but it felt like one cylinder running... and if you look at the plugs one of the prongs is still intact... Cylinder 1.
Im gonna go replace the plugs in a minute and see... thx
probly felt like 1 cylinder cuz your not sparking in your cylinders right. tell us if changin the sparkplugs helped. and you shoulda ran a wet setup too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">probly felt like 1 cylinder cuz your not sparking in your cylinders right. tell us if changin the sparkplugs helped. and you shoulda ran a wet setup too.</TD></TR></TABLE>Checked with the old spark plugs... still sounds like **** and smoked white from the engine and exhaust... i dont understand how this could have happened, i bought this kit cuz it was known as the safest... Maybe i shouldnt have had it installed by someone on the side, i woulda had it installed by a shop but here in san antonio its dead as ****, theres no good shops anywhere...learned my lesson, anyone wanna see pics of the setup?
you probably did what i seen ALOT of ppl do...incorrectly install the jets...or install only ONE jet...there are two jets...one in nozzle and one on the purple box...if these are switched this can happen..if these are put in incorrectly it may not function properly as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 »</TD></TR><TR><TD CLASS="quote">The Nitrous kit didn't blow your engine, you did.
Honda or not, your car's still 9 years old.</TD></TR></TABLE>
my car was a 98ls on the same 55 shot for much longer than his...cause my car was 8 years old should mine have blown too??? thats a lil bit of ignorance if you ask me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">
my car was a 98ls on the same 55 shot for much longer than his...cause my car was 8 years old should mine have blown too??? thats a lil bit of ignorance if you ask me</TD></TR></TABLE>Thx and i agree... i knew a guy with a 123k gsr runnin ten pounds of boost... Oh and i babied my nine year old integra with routine maintenance, 77 thousand miles, lucky number 7's got me
