What ya think?
So u know the deal... What cha think? Good deal? Appreciate the help from u guys so far. Thanx. http://www.autotrader.com/fyc/...color=
94 Civic Hatchback CX
Clear title
Exterior-
No rust AT ALL
Custom Red Paint
All new gaskets and Bolts
15' tenzo-r rims flat black with a red lip
4 brand new kuhmo ecsta tires 205/50/15r
500whp axles brand new
Skunk2 lugnuts
Shaved antenna
Seibon OEM carbon fiber hood
VIS carbon fiber tailgate
Smoked Vison amber corners
EX Front Lip
JDM Fog Lights
OEM Mud Flaps
-Engine-
B18c1 - 4000 miles -leaks burns nothing at any rpm ( completely rebuilt )
B18c5 - Type-R LSD tranny
11:1 Compression
Exedy stage 2, Cerametallic 3-puck clutch
Exedy lightweight 8.5 lb chromoly flywheel
Integra xsi valve cover
Peak Stage 2 Cams
Peak Cam Gears
Skunk2 valves and retainers
Milled head
Block is bored
SRP pistons
Type R Rods
Skunk2 intake manifold
Real J's Racing CF intake
Hks Filter
Greddy oil catch can
ITR header heat wrapped
AEM Fuel Rail
STR fuel pressure regulator
Megan Racing Exhaust / test pipe
Suspension/Brakes-
Type-R control arms
Apexi EXV full coilovers (32-way)
Skunk2 camber kit
GSR brake setup on front and rear Brembo slotted rotors
Steel braided brake lines
Axis pads all around
Rear Tower bar
Lower Strut Bar
Interior-
Apexi VAFC
GSR Leathers ( Front Only )
Black EG leather in back
Rear stripped
Ex Gauge Cluster
Black carpet
Integra floormats
JDM amber clock
Radio block off plate
Skunk2 short shifter and weighted shift ****
JDM Audio Console
JDM Arm Rest
Clear title
Exterior-
No rust AT ALL
Custom Red Paint
Skunk2 lugnuts
Shaved antenna
EX Front Lip
JDM Fog Lights
OEM Mud Flaps
-Engine-
11:1 Compression
Peak Stage 2 Cams
Peak Cam Gears
Milled head
Block is bored
SRP pistons
Type R Rods
Hks Filter
AEM Fuel Rail
Suspension/Brakes-
Type-R control arms
Skunk2 camber kit
Rear Tower bar
Lower Strut Bar
Interior-
Apexi VAFC
Rear stripped
Ex Gauge Cluster
Black carpet
Integra floormats
JDM amber clock
JDM Audio Console
JDM Arm Rest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboi07 »</TD></TR><TR><TD CLASS="quote">heres the parts list for the 94 civic</TD></TR></TABLE>
not bad, at least get it down to 8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen »</TD></TR><TR><TD CLASS="quote">8k would be an ok downpayment for a new house
fixed
</TD></TR></TABLE>fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboi07 »</TD></TR><TR><TD CLASS="quote">my bad man. Im new as u can see. Im still learning ya know? Like I said... My bad.</TD></TR></TABLE>
Thanks much
Thanks much
ki3t
Apr 16, 2005 01:41 PM
RTCdominicano
Mar 17, 2005 07:48 AM
