SOHC OBDO ecu question
Old Jul 12, 2006 | 02:49 PM
migizzel's Avatar
Default SOHC OBDO ecu question
well i got on my car to go to work this morning everything normal but then i glanced at my ecu wich i have the carpet pulled just a littel because i did some dataloging last night . anyways i looked at it and the led was blinking a 3 and a 7 but my check engine light was was not on so i checked the bulb and its good the car drives fine what could it be?
any ideas?
Old Jul 12, 2006 | 04:41 PM
Mach69's Avatar
Default Re: SOHC OBDO ecu question (migizzel)
You have a codes 3 and 7. Period. I call those codes, hidden codes. You have them. Nothing wrong with the ecu.
Old Jul 12, 2006 | 05:06 PM
rioninja's Avatar
3 and 7 are map and throttle position. At one point, the ecu detected a problem with these two. It will store the codes and blink until you reset it. Even if they are not currently problematic.
Old Jul 12, 2006 | 05:56 PM
migizzel's Avatar
Default Re: SOHC OBDO ecu question (rioninja)
well you do learn something new every day thank you guys
bk7794
May 29, 2012 09:32 AM
impact_blu
Aug 18, 2005 01:36 PM
conesmasher
Aug 31, 2004 09:12 PM
madflava
Oct 15, 2003 11:18 AM
TurboRedSi
Jul 17, 2003 10:59 PM
