2 problems with my 4th gen prelude. help please
hey guys, im having 2 issues with my prelude and im deciding whether or not to fix it or sell her and get something new. heres my problems:
1. when i turn my a/c on it works fine, blows cold air...but then after like 10 minutes it stops blowing anything at all. same thing with the heat.
2. sometimes when i press in my clutch, theres like no tension and i cant get it in gear at all. then after a while, theres a little tension and i can barely get it in gear. then the next day, the clutch feels fine and theres perfect tension. is my car possessed or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 »</TD></TR><TR><TD CLASS="quote">bleed the clutch line</TD></TR></TABLE>
AC/heater issue sounds kinda like a short wich could be either a big problem or a small problem.
it could be the thermal switch mounted on the actual compressor that turns it off if it gets too hot...and it could be getting hot because of worn bearings...its an easy place to start anyway
