Timing Belt Tension.
Old Jul 12, 2006 | 11:05 AM
98TypeSH's Avatar
Default Timing Belt Tension.
Exactly how tight does the T belt need or not need to be ?
I did the auto to manual conversion some time ago. I just now am starting to get some weird *** whining noise that i suspect is the T belt being over tensioned.
Old Jul 12, 2006 | 02:24 PM
PrettyLude's Avatar
if its whining its too tight, it needs to have little or no slack at all
Old Jul 12, 2006 | 03:17 PM
1epmugenlude's Avatar
I noticed that mine has been making that whining noise as well, should I loosen it or will it just go away in time?
Old Jul 12, 2006 | 06:25 PM
GlenWatkins's Avatar
Default Re: (1epmugenlude)
The timing belt should be as tight as the spring attached to the adjustment idler pully makes it. That's it's purpose. The whinning may be the idler pully bearing.
Old Jul 12, 2006 | 09:20 PM
MrLude1's Avatar
Default Re: (GlenWatkins)
^ or lack of a washer between the two....
Old Jul 12, 2006 | 09:21 PM
MrLude1's Avatar
at least it was in my case....
Old Jul 12, 2006 | 09:49 PM
98TypeSH's Avatar
Default Re: (MrLude1)
i have the washer on it.
I just picked up the rest of my tools from my old house, so ill just pop the crank pully off and losen it up and reset the tensioner.
Old Jul 14, 2006 | 07:28 AM
98TypeSH's Avatar
Default Re: (98TypeSH)
Taking the crank pulley and the cover off really isnt necessary.
Just get the trusty 14mm closed wrench out and pop the main bolt lose, push on the belt a little, maybe rotate a little bit on the crank, and lock it back down. problem solved.
nicknack25
Apr 10, 2012 11:00 AM
ka0s187
Dec 14, 2005 12:25 PM
fasthatchb18c1
Apr 19, 2005 11:30 AM
petrv
May 4, 2004 03:39 PM
petrv
Feb 25, 2004 10:32 PM
