2006 civic engine question
Old Jul 12, 2006 | 08:20 AM
zenon8890's Avatar
Default 2006 civic engine question
my friend imports engine from japan, he has a civic 2006 entire engine with everything (tranny,harness, ecu...ect) can i fit it on my 88 rex?
and if i could whats the specs on it, i know its 1.8 i-vtec
Old Jul 12, 2006 | 08:27 AM
crx_88_si's Avatar
aside from the normal k-swap stuff you would need to change the intake manifold to a RSX-s because the 06 uses drive by wire.
im sure there are other special things too.
Old Jul 12, 2006 | 08:29 AM
CRXBart's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">aside from the normal k-swap stuff you would need to change the intake manifold to a RSX-s because the 06 uses drive by wire.
im sure there are other special things too.</TD></TR></TABLE>
He said 1.8l Sounds like worthless swap to me. Just do a b series, unless you have the cheddar to do a K20a.
Old Jul 12, 2006 | 08:32 AM
zenon8890's Avatar
he claims the engine has 150HPs on it, and i'm getting it so cheap so why not?! can i know the specs of that engine?! it came of a sedan
Old Jul 12, 2006 | 08:39 AM
CRXBart's Avatar
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">he claims the engine has 150HPs on it, and i'm getting it so cheap so why not?! can i know the specs of that engine?! it came of a sedan</TD></TR></TABLE>
Do a b16 if that is all it is.
Old Jul 12, 2006 | 08:44 AM
zenon8890's Avatar
Default Re: (CRXBart)
d series engine are expensive in my country and doesnt have spare parts, i know 3 guys have type R engines and they removed it cuz the didnt find a spare tranny. what series is the 06 civic 1.8 engine?! i wish someone just tell me specs
Old Jul 12, 2006 | 08:49 AM
CRXBart's Avatar
Direct from Hondas website, they list no engine code.
Engine Type In-Line 4-Cylinder
Engine Block/Cylinder Head Aluminum-Alloy
Displacement (cc) 1799
Horsepower @ rpm (SAE net, Rev 8/04)* 140 @ 6300
Torque (lb.-ft. @ rpm) 128 @ 4300
Redline (rpm) 6800
Bore and Stroke (mm) 81 x 87.3
Compression Ratio 10.5:1
Valve Train 16-Valve SOHC i-VTEC®
Old Jul 12, 2006 | 08:51 AM
zenon8890's Avatar
thanks man, i'll post pics if i did the swap
Old Jul 12, 2006 | 10:14 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Sounds like the new series of motor. Non K-series, I think.
Old Jul 12, 2006 | 10:17 AM
crx_88_si's Avatar
ahh i missed that part. this engine he is talking about comes in the base coupe/sedan. It's the R-Series motors. (new).
Yuta
Nov 1, 2015 08:20 PM
Tims Toy 500
13
Aug 16, 2010 06:30 AM
3gcvcd16
Classic Hondas
Jun 20, 2007 06:02 PM
mystrchef
Feb 10, 2006 05:05 AM
Jun DC5
Jul 25, 2003 09:22 AM
