h22a swap
Old Jul 12, 2006 | 07:51 AM
soundFX's Avatar
Default h22a swap
im going to buy a newer h22a for my prelude and i found the best deals on hmotorsonline.com and have heard good things about then.
- Motor
- Hydraulic Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
-shifter assembly -Stock Motor Mounts
- Alternator
- Starter
- Clutch =2199
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- Motor
- Hydraulic Tranny
- ECU (P13)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold =1950
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
are the axles with halfshaft, shifter assembly, shifter cables, stock motor mounts worth the extra 240 or can i pull them off the h22a i have now?
Old Jul 12, 2006 | 08:04 AM
MadCityLude
Guest
Posts: n/a
Default Re: h22a swap (soundFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundFX &raquo;</TD></TR><TR><TD CLASS="quote">
are the axles with halfshaft, shifter assembly, shifter cables, stock motor mounts worth the extra 240 or can i pull them off the h22a i have now?</TD></TR></TABLE>
It depends, how many miles are on the current setup? Any issues at all with any of the parts? You could always get all the extra stuff and sell it here! You could prolly make a few extra bucks off it all!
It also never hurts to have an extra set of axles laying around either!
Modified by MadCityLude at 11:56 AM 7/12/2006
Old Jul 12, 2006 | 11:44 AM
soundFX's Avatar
Default Re: h22a swap (MadCityLude)
is it worth it to keep the engine with 80k on it and get the crankshaft fixed and not buy a new engine or just get a new engine with less miles. the crankshaft needs to be fixed or replaced.
Old Jul 12, 2006 | 12:00 PM
paulwithap's Avatar
it's gonna cost almost the same, and you get a better engine with the swap.
Old Jul 12, 2006 | 02:53 PM
MadCityLude
Guest
Posts: n/a
Default Re: (paulwithap)
What happend to the crank? I have an extra crank here!
Old Jul 12, 2006 | 08:42 PM
Bmodern528's Avatar
A buddy of mine picked up a type-r motor for his integra from HMotors. After all the trouble he had with it I would have to warn even my worst enemy against it. It started right up but before it left the garage it needed a new clutch because the throwout bearing was installed backwards, the pressure plate was missing a couple finger, and half of the clutch disc was gone. Just giving you the heads up.
Old Jul 12, 2006 | 09:00 PM
JDMPaulWall's Avatar
Default Re: h22a swap (Bmodern528)
I made a post about Hmotorsoline about a month ago. Alot of mixed feelings towards them, I would recommend to stay away. Check it out for yourself https://honda-tech.com/zerothread?id=1669177
Old Jul 13, 2006 | 02:11 AM
mat18's Avatar
Hmortors is cool, go through steve. what sucks for you guys is you cant see what your buying. when I bought my engine I picked it up myself.
Old Jul 13, 2006 | 01:12 PM
soundFX's Avatar
Default Re: (mat18)
so where else is a reliable place to get a swap from with low miles?
Old Jul 13, 2006 | 11:22 PM
paulwithap's Avatar
HFUCKINGMOTORS, or ask wherever you're getting the swap done if they have a preffered source, or if they don't have one, ask another import/performance shop in town.
aaronboy123
Mar 22, 2009 01:13 PM
Jerry31
Jul 4, 2004 11:32 AM
ForcedAccord
Dec 23, 2002 04:33 PM
ForcedAccord
Dec 17, 2002 11:08 PM
ForcedAccord
Dec 17, 2002 12:48 PM
