? on unpluged sensor...what is it?91 Si
Want 2 know what this plug is and where it goes
i have a plug looking thing that is obiosly unplugged..,. it is a circle round shape...... and this is on my wiring harness forgot 2 mention well has three wires plugged into it they are Green/white,,,,,,Red/Blue,,,,,,Yellow/white what plug is this? its all obd0 and a 91 Si harness
THANKS
THANKS
well its part of the harness and its got the wire colors i put up dont know where to plug it in? this might be why my engine light is on!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-8442- »</TD></TR><TR><TD CLASS="quote"> this might be why my engine light is on!!!</TD></TR></TABLE>
OH **** yeah thats it and after looking at the place it goes plugged in it is broken how can i change that do i need the whole throttle body? and the plug on mt sensor (wiring harness) it is half broken also how can i change those out because i have the sensor plug i got from a bone yard.? Can i just wire the same cables together again or what?
From: I told you to wait in the truck in Texas, United States
To remove the old sensor,Take a dremel with a small
cutting wheel and cut slots the bolts..
[They look like rivets,but are bolts with no head.. ]
Then unscrew the bolts with a flat blade screwdriver..
To calibrate the new sensor see:
http://www.integra.orcon.net.nz/tps
If just the plug is messed up,you can remove the wires and tranfer them to the new connector..
k thanks .....2 more problems happened today my starter BLEW up one of the mounting sides in which the bolts go.....the idiot before me only put one nut thing back on stupid ***! well changed that today . 2). my car started to overheat=Not fixed yet dont know whats wrong starting new post with this one so write on the other one please
e jay one
17
Sep 9, 2005 05:15 PM
