Ebay lightweight crank pulleys, are they any good?
Old Jul 11, 2006 | 10:13 PM
95dc2teg's Avatar
Default Ebay lightweight crank pulleys, are they any good?
Are these lightweight crank pulleys from ebay any good? Are they the same size as the stock one? Im pretty interested in these so if someone has any experience with them please let me know!! thanks.
ps heres a picture and detail
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jul 11, 2006 | 10:21 PM
Fat Chick Magnet's Avatar
wtf is hiprospeed? i wouldnt trust it.
Old Jul 12, 2006 | 01:56 AM
qfast817's Avatar
Default Re: (dc2rtek)
50 bucks for a knock off, i have a unoradox racing under drive pully for sale for 85
Old Jul 12, 2006 | 08:43 AM
JThrasher79's Avatar
Default Re: (qfast817)
i wouldent get anything other than the stock one. i herd some guys the timing marks were way off..
Old Jul 12, 2006 | 08:59 AM
Dforce's Avatar
That's what she said!
Default Re: (JThrasher79)
Old Jul 12, 2006 | 09:01 AM
96 GSR-T's Avatar
Default Re: (Dforce)
Underdrive anything but your crank! Your oil pump will thank you Fluidamper if you got the cash.
Old Jul 12, 2006 | 09:32 AM
ECKOTYPER's Avatar
think about waht you are asking... a ebay item, thats hella cheap... NO i think it can mess the motor up... id spend the extra $ and get the ctr pulley, then no damper in it either, u can send ur GSR etc... crank to inlinefour, and they lathe it down to a one pulley, but u still ahve the damper in it... i always just kept my gsr pulley on no matter what
Old Jul 12, 2006 | 09:45 AM
jdmluva's Avatar
Default Re: Ebay lightweight crank pulleys, are they any good? (95dc2teg)
The weight of lightweight crank pulleys is not good because it is too light. The OEM pulleys are balanced for Force, etc. in accordance with the Crank shaft and the Pulley attached to it. The only good thing the light aftermarket lightweight pulley brings to the your ride is the variety of colors.
Old Jul 12, 2006 | 10:08 AM
SilverDc2's Avatar
Default Re: Ebay lightweight crank pulleys, are they any good? (jdmluva)
CTR pulleys are 55-60 at hmo, just go with that, i doubt its any light, i believer the ctr oem is 1.5 lbs.
Old Jul 12, 2006 | 10:20 AM
95dc2teg's Avatar
Default Re: Ebay lightweight crank pulleys, are they any good? (SilverDc2)
alright, the reason i was asking is because I bought str power steering and alternator pulleys and was wondering if I should get the crank one too...i guess i will just stick with the stock gsr one. thanks for the info guys
Old Jul 12, 2006 | 10:34 AM
SilverDc2's Avatar
just yank out your powersteering if concerning about freeing up a few HP
Old Jul 12, 2006 | 02:28 PM
RHDintegXsi's Avatar
the thing you have to worry about is the oem crank is designed to damper an resonance in the crank..there is a myth that undampered lightweight crank pullies cause cranka nd rod bearing to wear prematuraly..that said i still run a ctr n1 crank and love it
Old Jul 12, 2006 | 03:29 PM
ucd
Guest
Posts: n/a
Default Re: Ebay lightweight crank pulleys, are they any good? (SINFULintegXsi)
Its more wear on your engine.
umair
Oct 26, 2007 06:21 PM
chu77
Jul 3, 2006 12:51 PM
bulori
Jun 15, 2006 12:51 AM
spacetuna
Jun 6, 2003 04:36 PM
