AEM (UEGO) Wideband Gauge - IN STOCK !
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features:
• 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
• Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
• User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
• Ideal AFR monitoring tool for carbureted applications and engine dynamometers
• Does not oscillate AFR like narrow band sensors
• Serial data stream included for output of AFR (RS 232)
• Accurate to 0.1 AFR
• Bosch UEGO sensor included
• NEW! Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
• NEW! Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
• NEW! Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
AEM (30-4100) Gauge-Type UEGO Controller (Six-in-One) *
Was: $332.77
<FONT COLOR="Red">Now: $280.00 (Free Shipping*) 150 gauges in stock !</FONT>
SPECIAL-----> $250.00 with the purchase of AEM EMS (http://phantasmusa.com/ems.html)
* Free Shipping Available on selected items, within the 48 United States.
Many other AEM produsts in stock. Please call to check stock... We will match any Legitimate prices...
Modified by PhantasmUSA at 3:11 AM 8/1/2006
.CUBISH.
67
Jul 9, 2008 12:19 PM
CIRCLEK
Sep 2, 2007 12:32 PM
CIRCLEK
Aug 21, 2007 09:51 AM
