head gasket question on d16a6
Old Jul 11, 2006 | 08:45 PM
charlie_sohc's Avatar
Default head gasket question on d16a6
will the stock 96 head gasket be ok for the block...its been bore .20 over(75.5mm) or i have to get the 75.5mm bore for it??
Old Jul 11, 2006 | 08:54 PM
Mavrick's Avatar
Default Re: head gasket question on d16a6 (charlie_sohc)
the bore of the headgasket has to match the bore of the block or you will eat headgaskets
Old Jul 11, 2006 | 11:14 PM
onepoint6i's Avatar
you'll be ok with a stock bore gasket,
im assuming you'll be useing a 96 head....
mini me setup?
Old Jul 12, 2006 | 05:21 AM
91SiZ6's Avatar
Stock head gasket bore is 76mm. And yes, '88-'00 D16 head gaskets are interchangable.
boostjunkieee
Mar 30, 2007 03:07 PM
riceball777
May 17, 2004 07:10 PM
