Best way to get the Rotors off (read: those damn screws!)
Old Apr 20, 2002 | 10:30 AM
Todd00's Avatar
I said I don't want a title!
Default Best way to get the Rotors off (read: those damn screws!)
On a 13K mile R, you'd think that the screws that hold the front rotors would come right off. Nope, can't be that simple.
So, before I strip the f*ck out of those screws and end up drilling them out, is there a better way to do it to get them off?
Old Apr 20, 2002 | 10:32 AM
Misfit's Avatar
Default Re: Best way to get the Rotors off (Todd00)
get a big ******* hammer.. nahhh... hey have you tried wd 40.
Old Apr 20, 2002 | 10:51 AM
SlowAndPsst's Avatar
Impact driver.
Like this one - only with a #3 Phillips-head screwdriver bit. CLICK HERE
Old Apr 20, 2002 | 10:54 AM
Mike M's Avatar
Founding Member
Default Re: Best way to get the Rotors off (JFedler)
Impact driver.
Old Apr 20, 2002 | 10:55 AM
D's Avatar
D
can pick up impact driver at pep boys/discount auto, whatever, for like $20.
Old Apr 20, 2002 | 10:57 AM
Impact driver.
Like this one - only with a #3 Phillips-head screwdriver bit. http://buy.snapon.com/catalog/pro_de...re&dir=catalog
Sorry for the long link...
Testhttp://buy.snapon.com/catalog/pro_de...re&dir=catalog
Old Apr 20, 2002 | 02:14 PM
Teepo's Avatar
Default Re: Best way to get the Rotors off (D)
hammer and a thin punch........you figure it out...works for me
Old Apr 20, 2002 | 02:47 PM
JPP's Avatar
JPP
I just finished replacing my rotor 30 minutes ago. A have a 98 ITR an the two front rotor were never taken off. They only way I manage to take those damn screws off was to drill them out and use one of those special bit to unscrew them. An impact wrench was no use.
If I may suggest, replace the philipp's flat head screws by flat socket head screw ( "allen" flat head screws) they are a lot easier to work with. Let say that the two front rotors did not came off without a fight either
Old Apr 20, 2002 | 02:54 PM
pyromaster's Avatar
after using an impact screwdriver to get them off i suggest coating those buggers (or new ones) with some anti sieze http://www.pollardwater.com/emarket/...8lubricant.asp to make it easier for ya next time
Old Apr 20, 2002 | 03:04 PM
93B18's Avatar
Here's the easiest way and has worked for me on really old cars as well as the Acura.
Get a large bolt that has the same diameter end as the screw on the rotor. Place it over the head of the screw and take a sledgehammer and hit the head of the bolt as hard as you can like 3 times. Voila! Try it again and it should come off like cake. HTHs. Good luck.
Old Apr 20, 2002 | 03:12 PM
Default Re: Best way to get the Rotors off (pyromaster)
Old Apr 20, 2002 | 03:29 PM
RagingAngel's Avatar
My vote is for an impact screwdriver!
Thanks G3-TEG for the hookup!
Old Apr 20, 2002 | 05:21 PM
Todd00's Avatar
Default Re: Best way to get the Rotors off (RagingAngel)
Sears hardware has the Impact thingies for $24.95 and they even come with a couple of phillips and standard bits. Picked one up tonight (along with a small drill bit just in case ).
Old Apr 20, 2002 | 05:23 PM
sackdz's Avatar
And once you get them out, leave them out, because they're useless.
Old Apr 20, 2002 | 07:04 PM
PHAT R 390's Avatar
New User
Definitely impact screwdriver. As long as you have the right phillips size, it should come right out provided you know how to use the tool. hehe Anyway, this is what mechanics use, so it's the right tool for the job.
eric416
Dec 2, 2009 02:55 PM
veilsides2000
Honda S2000
10
Apr 2, 2008 01:24 AM
crx18c1
17
Apr 9, 2007 04:02 AM
Filliam H. Muffman
Nov 16, 2004 12:35 PM
Drag-On23
Oct 28, 2003 08:29 AM
