where did you buy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 »</TD></TR><TR><TD CLASS="quote">what other alternatives are there to jun, crower, and skunk2s?</TD></TR></TABLE>
Why would you need anything else!
Theres always the Type S cams.
I recommend inlinefour as well.
Check the Official Camshaft Thread in the FAQ and most cams will be listed in there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 »</TD></TR><TR><TD CLASS="quote">i notice it was more a debate between skunk2 and crower plus a little info on the jun. that was about it.</TD></TR></TABLE>
^^That is true... lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu »</TD></TR><TR><TD CLASS="quote">Its probably best to pick the camshaft in reference to your goals.</TD></TR></TABLE>
^^Also true.. Cam depends on Build... And vis versa, build depends on Cams...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 »</TD></TR><TR><TD CLASS="quote">well let me put it this way:
car will be fully build, boosted and running a GT30R turbo. </TD></TR></TABLE>
Then you want turbo cams. Check Crower and Skunk. IMO, Crower is better for turbo applications.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu »</TD></TR><TR><TD CLASS="quote">Then you want turbo cams. Check Crower and Skunk. IMO, Crower is better for turbo applications.</TD></TR></TABLE>
I was always under the impression that stock cams were great for turbo because they are pretty strong.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">
I was always under the impression that stock cams were great for turbo because they are pretty strong.....</TD></TR></TABLE>
they are, you can make 500+whp with stock cams, and they wont break like aftermarkets
stock cams work great for na, and for a stock motor
there have been, many motors making well over 500whp with stock cams, there is no point to get aftermarket cams unless you want to lose reliability, and gain a few hp, same with cam gears you lose reliability but gain a few hp.
it depends on you if you want a reliable car..
all you need is some good valves, a 3 - angle valve job.. and your set
just incase you dont know, but valve guides are stock and u should already have them in your head, if they are leaky or loose, then youll need to replace them which your builder will determine that for you.
se93
Oct 28, 2002 08:12 PM
