I am new here.. CRX Si Turbo
I am fairly new to the site. I have been on and off of it but just joined. I am in Memphis, TN. I am picking up my first honda on thursday. Its a 1990 CRX Si. I already have a turbo kit waiting on it in the garage. TD04H Ball bearing turbo, front mount, new head with ZEX turbo cam, Skunk2 cam gear.. all the fun stuff. Any feedback of do's and dont's would be awsome. Will get pics up ASAP. Thanks
Modified by bnoland at 7:10 PM 7/13/2006
-Mugencrxsir1
Any recomendations of stuff to use? fuel pump, pressure regulator, SAFC, engine monitoring system?Thanks
I have a P28 (i think thats what it was, not sure of what it was call being new to hondas and all) ecu I am getting from a friend that he said I should have chipped by a guy on here to help with tunning.
yeah i have the best advise you will ever get. Do not let your motor see anyboost until you have a tuning plan. An untuned turbo car is the equivalent of kicking yourself in the nuts........ITS POINTLESS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnoland »</TD></TR><TR><TD CLASS="quote">-Any recomendations of stuff to use? fuel pump, pressure regulator, SAFC, engine monitoring system?Thanks
Turboedit, Warlboro HP 255, 440 or 450 injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnoland »</TD></TR><TR><TD CLASS="quote">-Mugencrxsir1
Some good ideas,
Pump, regulator, injectors, a full engine management system like hondata wouldnt be a bad idea.
Then start thinking about plugs, wires, ignition system boxes such as the XS Engineering amplifier, or an MSD set up.
replace that factory distriubtor cap with an aftermarket one that will accept an external coil
Just some ideas.
P.S. 600 POSTS AND STILL GOING STRONG!!!
Some good ideas,
Just some ideas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">Turboedit, Warlboro HP 255, 440 or 450 injectors
damn got to it before me. but chrome would be easier to use i think. either or is a good choice though.
</TD></TR></TABLE>damn got to it before me. but chrome would be easier to use i think. either or is a good choice though.
-Autoworks
I have pretty easy access to DSM injectors being that is what I was building before.. do they work well and what does it take to make them work with the honda?
Anyone have any ignition systems they like more than another? I know alot of people run MSD but the friend I got the turbo kit from was running MSD on his while it was turbo and didn't like it very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnoland »</TD></TR><TR><TD CLASS="quote">-Autoworks
DSMs work great, 390s and 450s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitally_remastered »</TD></TR><TR><TD CLASS="quote">
damn got to it before me. but chrome would be easier to use i think. either or is a good choice though.</TD></TR></TABLE>
Crome is OBd1
Turboedit is OBD0
Crome is OBd1
Turboedit is OBD0
DSMs work great, 390s and 450s. </TD></TR></TABLE>
Plug and play or is there something that has to be done to make them work? I can get 450's easy.
Why can I only make 5 posts in a 24 hour period? How do I get that changed? I can learn without asking questions
I am using a greddy ball bearing turbo and editing my post to be able to post again or else I have to wait till tomorrow
Why can I only make 5 posts in a 24 hour period? How do I get that changed? I can learn without asking questions</TD></TR></TABLE>
Shave them down to fit in the grommets in the fuel rail...nothing major, they plug right in.
Thanks for all the advice everyone. How do a become am acually member instead of a trial member? *edit* I guess that is just a first 24 hours thing cause it isnt there anymore.
Turboedit is OBD0</TD></TR></TABLE>
What is this.. I am not familiar with this? Does it run along side of hondata or is it another program like hondata?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by softball8624 »</TD></TR><TR><TD CLASS="quote">im new here too!
is your turbo mitsu?</TD></TR></TABLE>
Its a greddy ball bearing turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 »</TD></TR><TR><TD CLASS="quote">P28 = B series.
Being as cheap as I am, I'd get your ECU chipped and run turboedit, etc. </TD></TR></TABLE>
No you are wrong. The p28 ecu is d-series. It comes out of a 92-95 si, which have d16z6's.
So go ahead and use the p28 ecu and get it chipped.
It's also an OBD1 ecu. You should get it chipped for crome then. What type of head are you puting on it?
Does the car have the stock a6 in it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">Just don't skimp out on fuel parts/tuning, they are the most important part of a turbo project.
Agreed. welcome to the site
</TD></TR></TABLE>Agreed. welcome to the site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">if you're staying obd0, with the d16a6, i suggest you chip your factory ecu with turboedit
if you're going to obd1 with the d16z6/d16y8 or vtec head mini-me, i suggest you chip the p28 ecu with crome, uberdata, hondata, or something of the equivelent
DO NOT use vafc or FMU as a source of "tuning"
do it right the first time or dont do it at all
also, you're getting camshafts and cam gears and stuff, which is pointless unless you lay out your entire mod list, i wouldn't work on the head until i work on the block internally, honda heads are usually good to rev up to 8-9k rpm in stock form easily, but you have to reinforce the block to take the abuse (rods, piston, sleeves, headgasket, etc.)
take your time slowly, do it all correct the first time, also remember the little things you need to get your car running
vacuum lines, oil feed lines, oil "tee", oil return line (DO NOT KINK OR LOOP THIS LINE), bov, intercooler piping, clamps, downpipe, exhaust, colder spark plugs (recommend ngk bkr6e's), boost gauge, oil pressure gauge, water temp, relocated half size radiator, and some other stuff i'm forgetting</TD></TR></TABLE>What a great post well laid out and tons of info
I would agree 100% I just will add OBD1>OBD0. I am so happy with crome, not that I had problems with turbo edit to be fair.
I wouldn't try to take a stock bottom D 8-9K though. machine LS rods and ARP bolts for extra revs and psi
Thanks again everyone for the input. You seem to be a very supportive site with a good group.. not easy to find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 »</TD></TR><TR><TD CLASS="quote">everyone has mentioned what u would need for a turbo set up but i think theres one little detail no one asked...what motor is it that ur turboing?</TD></TR></TABLE>
D16A6.. I am going to stick with it. I have liked what I have seen out of it.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 »</TD></TR><TR><TD CLASS="quote">P28 = B series.
Thats kind of the route I am going.. I could spend all the money to convert stuff and what not but I am not doing this for the Mags. I just want alittle fun. Plenty of people seem to have bad this work well so that is what I intend to do.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">if you're staying obd0, with the d16a6, i suggest you chip your factory ecu with turboedit
Its not that I am getting it.. I got it on a good deal with the turbo kit. Its a rebuilt head with the zex cam and skunk2 gear. Like I said.. I am not looking to impress everyone with it. I just want it to be alittle quicker. I am already planning to buy another block to start building but in the mean time I am going to turbo this one. If it pops then it pops.. no big deal. I am staying D16a6 with it.
Where do I get the Turboedit done?
