swap in 90 civic hb
Old Jul 11, 2006 | 06:01 PM
r6king28's Avatar
Default swap in 90 civic hb
im putting an obd2 sohc vtec into an obd0 dual point 90 civic. what would i use for the wire harness?also what ecu do i use?and finally what axles do i use if im sticking with the stock cable tranny?plz help
Old Jul 11, 2006 | 06:54 PM
r6king28's Avatar
Default Re: swap in 90 civic hb (r6king28)
any one
Old Jul 11, 2006 | 07:06 PM
Floored's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r6king28 &raquo;</TD></TR><TR><TD CLASS="quote">im putting an obd2 sohc vtec into an obd0 dual point 90 civic. what would i use for the wire harness?also what ecu do i use?and finally what axles do i use if im sticking with the stock cable tranny?plz help </TD></TR></TABLE>
Please search before asking these questions they have been answered multiple times. In short though, you would use your wire harness already in the car, and wire it for mpfi and either leave it OBDO or convert it to OBD1 or 2. Depending on what you choose would depend on what ecu you used.
As far as the tranny you dont need to change axles, just use the same ones already in the car. If the car is a std i would swap the hubs and put in dx or si axles though. (they are stronger)
Anyway search and you will find more in-depth answers to your questions.
Old Jul 11, 2006 | 08:07 PM
r6king28's Avatar
thanks anyone else
Old Jul 11, 2006 | 08:12 PM
jdm_ef9_b16's Avatar
contact ryan at rywire.com about wiring and all that.
axles and tranny, what the other guy said, and u r probably better off going obd1.
Old Jul 11, 2006 | 08:34 PM
r6king28's Avatar
thanks but can i use an obd1 ecu on an obd2 motor
Old Jul 11, 2006 | 10:07 PM
Rywire's Avatar
Default Re: (aallbbeerrtttttt)
right on, let me know your setup, and ill do the wiring to your needs. Yes, obd1 ecu is allways a good choice
Ryan
Old Jul 12, 2006 | 07:38 AM
r6king28's Avatar
thanks guys pm sent
StanleyScotland
Jun 13, 2010 10:01 AM
JdM Dx
Aug 22, 2006 08:21 PM
Excelerate
Aug 17, 2006 07:16 AM
johnjw
Feb 25, 2004 05:28 PM
