DC2 GSR Brake swap onto ef.
My wheelbearing is pretty much seen better days so I figured since I am about to do rear disc I would do the fronts. I searched and came up clean. What would you need to complete DC2 GSR FRONT knuckles onto ef. Axles be the same? Camber/Caster differences? Links to possible swapee?
just get some civic EX knuckles, i don't think GSR's had any different calipers then rs or ls and GS. I could be wrong but my gsr calipers look exactly the same as 93 teg calipers.
if you want to upgrade your brakes go for the DA integra fronts its a direct bolt on..do not use the upper control arm..just the knuckle, caliper, and the brake line closest to the caliper. DC integra does not fit and will mess up the alignment
EF88Ty
Oct 16, 2018 10:33 AM
cleanazcoupe
Mar 27, 2010 11:43 AM
I heart My EF Sedan
Sep 7, 2007 11:38 PM
JokerTypeR
16
Nov 19, 2006 11:07 AM
