wiring issues....
Old Jul 11, 2006 | 04:49 PM
civickid03's Avatar
Default wiring issues....
Im throwing crazy codes right now but im hoping its just my KS. It isnt hooked up - i understand i need to run a wire to b19 on my pr3 ecu. Is there already a wire there? do i need to splice? can i just run the wire to the ks from b19 or do i need a special connector or something. im really unsure about how to do this. BTW could a knock sensor cause a TPS or IAC code because my TPS voltage is perfect .5 idle, 4.5 wot and smooth throughout the range. thx im a newb
Old Jul 11, 2006 | 04:56 PM
jacoop86's Avatar
Default Re: wiring issues.... (civickid03)
just remove the old b19 wire and put in the one for the knock sensor. if i were you, i'd work on clearing one code at a time, reset the ecu, then work on the next. but i dont know how a ks code could also throw a tps and iac...
Old Jul 11, 2006 | 05:01 PM
civickid03's Avatar
Default Re: wiring issues.... (jacoop86)
retarding the timing? im not sure
Old Jul 11, 2006 | 05:02 PM
civickid03's Avatar
this is a dx to mpfi conversion - no rywire - i can just remove the entire b19 wire??? What was it used for prior?
Old Jul 11, 2006 | 08:45 PM
jdeemseerx's Avatar
you probably have the plugs for the tps and iac switched.. try switching them around and disconnect the battery to reset the ecu.. this is common when doin swaps
Old Jul 11, 2006 | 10:12 PM
Rywire's Avatar
Default Re: (jdeemseerx)
the iacv and tps plugs are not the same, so prolly not switched.
make sure the iacv plug is black/yel and blue/yellow NOT the orange wire thats unused
did u swap the tps wires like it says in the many online directions? Just some ideas
Old Jul 12, 2006 | 09:31 AM
jdeemseerx's Avatar
i was thinking MAP oops it was late
thebleek
Jul 30, 2008 08:20 PM
JBirch_97Prelude
May 27, 2007 01:03 PM
Rob Dizzle
Feb 24, 2003 06:14 AM
