ZC to B16 wiring? what else is needed?
well i have a 91 dx, with a zc, and i just got a new 90 dx hatch. and i want to gut it, and put my zc in it, and in my old hatch, i want to do a b16. my friend has one, and is looking to get rid of it. so i was curious on what all the wiring difference is, i really dont know much about B series. all i know is the wiring for vtec. does anybody happen to have a good link or something? thanks alot HT!!!!!!!!!
sounds like your dpfi to mpfi is already done... all you have to do is wire your vtec pressure and solnoid, your knock and your 2nd o2 sensor
isnt the zc distributer plugs different than everything else? if you have a jumper harness no big deal, but you may have to redo the wiring for that. i think the zc plugs are square and b16/d16 are circle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 »</TD></TR><TR><TD CLASS="quote">isnt the zc distributer plugs different than everything else? if you have a jumper harness no big deal, but you may have to redo the wiring for that. i think the zc plugs are square and b16/d16 are circle.</TD></TR></TABLE>
What does the firing order have to do with the wiring?
Also there is only 5 wires to the dizzy it wouldnt be to hard to get that all figured out
yes, you will have to do some re-wiring of the distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tealhatch »</TD></TR><TR><TD CLASS="quote">what about a GSR motor?</TD></TR></TABLE>
You'd have to convert your car to obd1/2 ..or convert the engine to obd0
91tealhatch
Aug 7, 2006 10:17 AM
