how do you install a charcoal canister for LS 96+
does anyone know which line goes where for the charcoal canister
or have pics or diagrams of which hose goes where
for an 96 integra LS
thanx
thanx
why do you want do this??? it wont help you pass emission at all, its just a fuel vapor tank
btw, if u still want to put it in go ahead, but i would say hook the pcv vent on the valve cover to the intake, make sure the cat works properly, and if its chipped or has an ems, run a stock computer, like a p28,
if you have a stock hood the vaccume diagram is right on the hood
i swap in a b18b in to my civic and trying to get it BARed the civic canister is different from the LS one
the LS has an extra hose compared to the civic one
Check this post out, he has a diagram of the connections to the charcoal canister in some of the pics:
https://honda-tech.com/zerothread?id=1141806
See if that will help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 »</TD></TR><TR><TD CLASS="quote">there are four hoses i need to connect can u guys tell me where to put each one?</TD></TR></TABLE>
Looking at the diagram:
One top hose goes to the EVAP Purge Control Solenoid Valve.
One top hose goes to the nipple near the MAP sensor.
One top hose goes to the EVAP two way valve which connects to the fuel tank.
Not pictured, a purge air hose which connects to the bottom of the charcoal canister.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 »</TD></TR><TR><TD CLASS="quote">does the hose on the bottom go anywhere?</TD></TR></TABLE>
not on mine, i think it's just a dumptube.
