installing usdm or jdm itr doors on SE
Old Jul 11, 2006 | 03:10 PM
waddy41's Avatar
Default installing usdm or jdm itr doors on SE
questions:
if i was install usdm itr doors onto my SE...is everything just plug and play?
and if i was to install jdm itr doors...how would i go about doing so?
Old Jul 11, 2006 | 03:27 PM
Lan's Avatar
Lan
Default Re: installing usdm or jdm itr doors on SE (waddy41)
Are you talking about door panels? Or the whole door? Do you currently have power windows and power mirrors? If so, you'll be OK. If you get the JDM door panels you will need to drill out a hole for the tweets
Old Jul 11, 2006 | 03:33 PM
waddy41's Avatar
im talkin bout the entire door...i do have power windows and power mirrors..but what about adjusting the mirrors and the controller for both windows and trunk lock?
oh snap...would usdm itr juss be plug and play?
Old Jul 11, 2006 | 03:35 PM
Lan's Avatar
Lan
Default Re: (waddy41)
Yes
Old Jul 12, 2006 | 07:23 AM
waddy41's Avatar
what bout making rhd doors work?
Old Jul 12, 2006 | 08:40 AM
JThrasher79's Avatar
the rhd doors you would need to swap over your wire harness from your stock doors. its easy
Old Jul 12, 2006 | 09:24 AM
bg-33p's Avatar
Default Re: (JThrasher79)
what about the different key holes? do you just swap that from the old door?
Old Jul 12, 2006 | 10:38 AM
Default Re: (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">what about the different key holes? do you just swap that from the old door?</TD></TR></TABLE>
swap door handels, i almost forgot you gotta swap everything like the window motor and ****. still easy though, i did it with one hand..
Old Jul 12, 2006 | 11:40 AM
Leo C's Avatar
Night Owl
Speaking from experience, I have doors+ panels from a JDM ITR on my 95 rs. The easiest way to do it was to swap over the guts from my old ones to the ITR doors. I also had to swap over the window switches on the panels but that only took 10 seconds.
Old Jul 12, 2006 | 11:41 AM
Leo C's Avatar
Night Owl
Speaking from experience, I have doors+ panels from a JDM ITR on my 95 rs. The easiest way to do it was to swap over the guts from my old ones to the ITR doors. I also had to swap over the window switches on the panels but that only took 10 seconds. Also, neither me or my friend @ the bodyshop that did the work was able to get the mirrors to work. Good luck.
95lsvboy
Jun 7, 2013 09:15 AM
itr1235
Aug 13, 2008 02:55 PM
marko_think
May 27, 2005 11:15 AM
RuffGsR
Jul 7, 2004 07:15 AM
Turbo-JC
Audio / Security / Video
Jul 20, 2003 07:50 AM
