Steam coming from coolant reservoir hose.
Old Jul 11, 2006 | 02:15 PM
FalkenSiR's Avatar
Default Steam coming from coolant reservoir hose.
So the other day I noticed that after stopping the car there was a noise coming from under the hood. I popped it and the coolant reservoir was "boiling" I took the cap off and it was just hot steam coming from the hose (coming from radiator) There was a lot of coolant in the reservoir, like almost to the top. Now everytime I stop the car it will do this and "steam" for like 5-10 minutes and leak lots of coolant out (from the cap being under pressure)
Anybody heard of this happening? What could be the cause? There is no overheating whatsoever
Old Jul 11, 2006 | 02:20 PM
philosofy1's Avatar
Default Re: Steam coming from coolant reservoir hose. (fast95eg8)
your thermostat is bad, change it out and you'll be fine.
Old Jul 11, 2006 | 02:26 PM
FalkenSiR's Avatar
Default Re: Steam coming from coolant reservoir hose. (philosofy1)
Is it really? what is happening with it? Is it stuck or something?
Old Jul 11, 2006 | 02:28 PM
philosofy1's Avatar
yeah, when they go bad they stick.
Old Jul 12, 2006 | 10:09 AM
FalkenSiR's Avatar
Thanks philosofy, I bought the thermostat at honda for $25 with gasket and on my way home the damn thing overheated BAD. So bad the check engine light came on. Well, today I replaced the thermostat and it still overheats after reaching normal operating temperature.
There is no more bubbling coming from the reservoir anymore, tho, so that's one down.
One thing I noticed, the fans didn't come on at all. Fuses are fine but I'm thinking relay. My laptop is broken right now and I don't have access to my PDF helms, can anyone tell me where the "Fan Relay" is located?
Old Jul 12, 2006 | 10:26 AM
philosofy1's Avatar
did you try burbing the system after changing the thermostat.
as for the fans, how long are you waiting to see if they come on. oddly mine take a while to kick on in my 93 hatch.
Old Jul 12, 2006 | 10:29 AM
philosofy1's Avatar
i know when you don't let all the air out of the system it'll still overheat at running temps. let the car cool, open the radiator cap, start the car then add more fluid until you can't anymore then put the cap on and see what happens.
Old Jul 12, 2006 | 10:37 AM
Syndacate's Avatar
are u using 50/50 or pure anti-freeze? If 50/50 might wanna add more on the anti-freeze side.. Realistically though it sounds like there's a blockage in the system..but how long are you letting it idle that your fans aren't kicking on? If you're driving air cools it so there's no need for the fans to be on, so if you're driving and then you stop and pop the hood, the fans shouldn't be on, but then let it sit for a few and the fans'll kick on... If ur sure it's not kicking on the relay could be bad I guess...but it really sounds mor elike a thermostat problem, but u said u changed it so how could this be? Check ur mixture, check ur thermostat AGAIN, and thn I would move onto ur hoses, because it seems like there's a block or something..but even that's doubtful :-\
Old Jul 12, 2006 | 11:30 AM
Rock Meathammer's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">are u using 50/50 or pure anti-freeze? If 50/50 might wanna add more on the anti-freeze side.. Realistically though it sounds like there's a blockage in the system..but how long are you letting it idle that your fans aren't kicking on? If you're driving air cools it so there's no need for the fans to be on, so if you're driving and then you stop and pop the hood, the fans shouldn't be on, but then let it sit for a few and the fans'll kick on... If ur sure it's not kicking on the relay could be bad I guess...but it really sounds mor elike a thermostat problem, but u said u changed it so how could this be? Check ur mixture, check ur thermostat AGAIN, and thn I would move onto ur hoses, because it seems like there's a block or something..but even that's doubtful :-\</TD></TR></TABLE>
Thermostat was replaced with a dealer one. (doubt that is the problem) Try burping the system as philosofy said. If still that doesn't work, replace the cap. It might not be venting properly. Mixture is not the problem. Fans are supposed to cycle regardless of driving or not. I doubt there is a block in the system.
Old Jul 12, 2006 | 12:36 PM
FalkenSiR's Avatar
Default Re: (B20 EJ6)
Oh i see thanks guys. Yea I reach normal op. temp. and the fans didn't kick on. So I decided to open the relay box (under hood) and switch the 3 relays around until they kicked on. So I think it's the relay.
I will go burp the system right now. I've been waiting for it to cool down. It's 105 degrees out here right now
edit-what are teh 3 relays in the relay box? I have no labels. I know one is for the fan, one for the blower motor and the other one????
Old Jul 12, 2006 | 01:05 PM
Default Re: (fast95eg8)
If you have a 95 civic, then the cooling fan relay should be taped together with the condenser fan relay located in between the bumper and the condenser.
Old Jul 12, 2006 | 01:09 PM
FalkenSiR's Avatar
I searched and people said the relay was in the fuse box. IT DID work because I switched them around and they turned on when they were supposed to. I will go look at it right now. I burped the system and the hose isn't steaming anymore
The cap had a little metal ring inside of it and that was done for. It was all loose so I might have to get a new cap too. $22 at honda.
OK EDIT- When you open the relay box, there will be 3 black boxes, lined up vertically. This is the order from top to bottom:
1. Cooling (radiator) Fan Relay
2. Heater Motor Relay
3. Rear Window Defogger Relay
Now near the driver side headlight there are 2 more relays. They are the Condenser Fan Relay (for AC) and the A/C Compressor clutch relay.
Modified by fast95eg8 at 2:28 PM 7/12/2006
Modified by fast95eg8 at 2:29 PM 7/12/2006
Old Jul 12, 2006 | 01:28 PM
unknown0001's Avatar
same issue I've been having
https://honda-tech.com/zerothread?id=1684146
91civicsikid
13
Jun 24, 2014 03:23 PM
raju687
Sep 16, 2011 05:42 PM
SpazMan
Jun 12, 2008 10:22 AM
tigueremalo
Jul 10, 2006 07:16 PM
AllMotorDA9
Oct 27, 2005 03:49 PM
