test pipe install help!!!
Old Jul 11, 2006 | 01:20 PM
kaychi's Avatar
Default test pipe install help!!!
hye guys i came on here a while ago asking on how to install a test pipe for a crx si. got some good info and it seemed really easy. well today i tried to install it and while taking off the stock converter, i got the first two bolts off that was connected to the headers but when i got to the three bolts where the exhaust is everything just went wrong. a 14 was just a little bit too big and a 13 was just a little bit too small. i tried and tried to think of ways to take it off but with no luck. so i need help. have any of you had this problem? if so let me know.
Old Jul 11, 2006 | 04:14 PM
philkehn's Avatar
crescent wrench?
Old Jul 12, 2006 | 09:05 AM
kaychi's Avatar
Default Re: test pipe install help!!! (kaychi)
no i tried that it's too big and hits the exhaust so thats out of the picture. is there anything inbetween a 13 and 14 that i could use?
Old Jul 12, 2006 | 09:10 AM
Loserkidwac's Avatar
maybe one of those gator grip sockets but I just get a dremel on it and shave it down a little to fit the 13mm and then just replace it once its out
Old Jul 12, 2006 | 09:37 AM
91civicEX's Avatar
washington eh. i bet those bolts are rusted to ****. try some vice grips or this thing called bolt out. bolt out has saved my *** many times
Old Jul 12, 2006 | 09:40 AM
jedubz's Avatar
Yeah spray some De-Rust chemical on it (apply liberally) and hit it with a socket if your crescent wrench doesnt work... I seriously can not see a situation where you can't use a crescent wrench down there though.
Old Jul 12, 2006 | 11:00 AM
QuarterMileMaster's Avatar
Default Re: (SloS13)
Did you ever think someone could've put a standard sized on there??? I'd say try that...
Old Jul 12, 2006 | 01:12 PM
kaychi's Avatar
man today i went and looked at it again and the bolts are rusted to **** it even looks like it's part of the screw now. i think i might just try to take it to the muffler shop and see if they're willing to put it on for me. the only thing is it's for off road use only so i dont know.
Old Jul 12, 2006 | 01:21 PM
Tippyman's Avatar
Saw-zall FTW. Right between the two pipes...
Old Jul 12, 2006 | 01:24 PM
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Saw-zall FTW. Right between the two pipes...</TD></TR></TABLE>
Or try to use a standard socket to see if that will grab it. If that doesn't work try the above or air chissel the crap out of it...
Old Jul 12, 2006 | 03:28 PM
Floored's Avatar
Default Re: (QuarterMileMaster)
I just ran into the same problem when installing my new exhaust. What I did was I took my grinder with a cutter wheel and ground off the end nuts that face toward the back of the car. Once they were ground down, I used a punch and hit those suckers out.
Old Jul 12, 2006 | 03:43 PM
1990si's Avatar
Yea, when i had to replace a reinforcement on my rear bumper i had to cut out all the rusted nuts and bolts with a pheumatic air grinder and grinded them off and replaced with new nuts bolts.
Old Jul 12, 2006 | 04:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Soak it with P-B blaster:
Heat it up with a torch,
Mapp gas is better,but even a small butane one like this will do:
Heat and soak several times and
then use one of the sockets for stripped nuts like this:
http://www.amazon.com/gp/produ...28013 http://www.amazon.com/gp/produ...28013
Also:Coat the studs with anti-seize compound for next time you have to do this,,
Old Jul 12, 2006 | 04:10 PM
mrtoastyjr's Avatar
Default Re: test pipe install help!!! (88DXCRX)
id say try and hammer the 13 on and start with that. mabey even get a 12 point 13mm. if not then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
i use these little jems at work EVERY day for exhaust work. they never failed me!
Old Jul 12, 2006 | 04:12 PM
h224thgensedan's Avatar
for pb thats what i had to use to get mine off when i made my test pipe. Also it makes it a little easier if you drop the exhaust hangers. You can get to it better. Just let the pb soak for a while then respray it and then go for it.
Old Jul 12, 2006 | 04:50 PM
Crx Jimmy's Avatar
heat em up even a propane torch can get the rust glowing red. once its red hot , dump ice cold water on them, do this a couple times for each nut. the expansion and immediate contraction from the temp difference will break the rust
Ekzc91
10
Apr 15, 2009 10:42 AM
kaychi
Jul 1, 2006 11:34 AM
ITB
Nov 20, 2005 07:22 PM
Del Souless
May 26, 2005 05:35 PM
zer0zer0 TypeR
Jul 30, 2002 06:33 PM
