USDM 3rd gen integra (94-01) Cluster Information... instrument panel/gauge cluster/speedometer
Just something for all of your references:
All of 4 gauges can be interchanged between all years
The white cluster panel piece on 94-97 is differnt from 98+, automatic and manual have same part number for that piece on all years
The clear plastic cover is interchangeble between all years but some have rubber inserts around where tripometer goes
Black cover (that goes right behind the clear plastic cover) has 3 versions:
94-97 (abs light is on the bottom while fasten seatbelt is on top)
98 (abs is next to srs while seatbelt is on the bottom)
99-01 (has green immobilizer key on bottom left)
Green Film has 6 versions:
2 94-97 5 speed and automatic
98 5 speed and automatic
99-01 5 speed and automatic
gauges themself will vary however.. if you unbolt them they should snap right in and work
other minor differences would be 3 main lightbulb color for itr models as well as cosmetic trim of gauges or black panel.
so, the best way is.. to swap gauges, changing green film alone won't do the trick. you could also repin the harness for connector - i'm not sure if you'll be able to retain the abs light by doing that.
i dont have pics but if anyone want to upload different models to this thread, feel free
something i will never use, but something i know know.
thanks for taking the time to share the info.
VolkswagenWHO!!!
Sep 20, 2006 05:02 AM
