How do I tell if this EG LCA accepts a sway bar?
Can someone tell me what to look for on these EG LCAs, whether or not they will accept a sway bar? Or are all EG LCAs the same (not different versions like EK?)
Running an EG Manual Rack, Rear Crossmember, and EG LCAs on my 96 hatch
I should have specified, this is for the FRONT only
Modified by o2flow.net at 6:53 AM 7/12/2006
their are 2 things to look for if it is a stock arm most of them have a threaded bump on top of the control arm just to the inside of the shock the other tyoe have a hole in the control arm its self just to the inside of the shock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">SI/EX came with them for sure.</TD></TR></TABLE>
the only one that I am aware of coming with rear sway bar was a 4 dr ex model the si did not come with them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyzbus »</TD></TR><TR><TD CLASS="quote">Nope, no hole for the sway bar to mount to</TD></TR></TABLE>
FAWK, anyone know if only Si Front LCAs have the holes or can I use EX Front LCAs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">FAWK, anyone know if only Si Front LCAs have the holes or can I use EX Front LCAs?</TD></TR></TABLE>
The EX had a factory front sway bar, so yes, you can use EX LCAs.
spoon95eg
Suspension & Brakes
Apr 11, 2006 09:14 PM
Jon V
16
Jul 3, 2004 06:54 AM
